Low compression
Old Aug 17, 2012 | 01:20 PM
75hdxlh1000's Avatar
75hdxlh1000
ok will do.....thank you!
Old Aug 17, 2012 | 01:27 PM
XL50#674's Avatar
XL50#674
If i were you I would not reuse the pistons, i would pull the jugs, have them checked and go with a .30th overbore just to be safe and pick up a bit extra power while your at it.
Old Aug 18, 2012 | 09:44 PM
75hdxlh1000
Ok I got the heads off today and took a pic... I am going to change the pistons and rings...would .030" be the ideal overbore?
Old Aug 19, 2012 | 10:10 AM
mrfikser's Avatar
mrfikser
I am looking at the pistons and rings and they look fine to me (from what I can tell from the pic)...how does the front head look???, any signs of a burnt valve???
Old Aug 19, 2012 | 05:21 PM
75hdxlh1000
well the valves looked good but I noticed one of the rocker arms was sticking in the head assembly. I tried to pull one of the rings off and it broke in half!
Old Aug 20, 2012 | 11:10 AM
mrfikser's Avatar
mrfikser
yea, the rings are easy to break thats for sure...I would say the problem is in the head (the bikes, not yours)...If I were you I would go ask at the classic forum...they probably have more info on your bike..
Old Jun 18, 2017 | 10:18 AM
kylecbruno92@gmail.com's Avatar
Stage II
Default 75 iron head
Hey guys I have a 75 iron head and I'm having similar issues with my compression my front cylinder is pushing 105 psi while my rear is only pushing 35 psi. Plugs are dry what am I looking at needing to do to fix this issue
Old Jun 19, 2017 | 09:50 AM
mrfikser's Avatar
mrfikser
do you realize that this posting is like ancient??...that said...I would start a new thread in the classics section, I am sure you will get a good bunch of replies....there is a series of tests you can do to help you get closer to the exact problem if not pinpoint it...low compression in just one cylinder is usually (if you are sure you did the rest right) a burnt valve, a wiped cam or some other part of the valve train being messed up or a cylinder ring issue..I would put my money on a valve issue and not a ring problem because it is only in one cylinder and 'usually' when it comes to rings both cylinders pretty much wear out the same amount (but not always)...do a forum search for low compression...do the tests and pretty soon you will be back on the road...
rkingstp77
Nov 19, 2013 05:58 PM
73 ironhead guy
Ironhead
Sep 19, 2012 07:35 AM
2009blackpearle
Aug 12, 2012 08:44 AM
sportster77
Ironhead
Aug 7, 2011 09:27 AM
ridefree1
Ironhead
Mar 18, 2011 07:34 PM
