Vss?
Old Aug 15, 2012 | 07:09 PM
xbmxxx's Avatar
xbmxxx
4th Gear
Default Vss?
After doing a tank lift/wire tuck on my 09 xl883l I am throwing a code for my VSS and my speedo is intermittent. I am trying to trace the wires to make sure all the connections are good, but they go in to the large loom right off the sensor and I lose them. Does anyone know what connector under the tank they go in to and where they go from there?
Old Aug 15, 2012 | 07:24 PM
Scuba10jdl's Avatar
Scuba10jdl
There is a wiring diagram in the back of your FSM. You can compare the wires on the connectors to the wires that match for the VSS and then you will know which connector it is.
Old Aug 15, 2012 | 07:38 PM
xbmxxx's Avatar
xbmxxx
4th Gear
I don't have access to a FSM right now, and won't for a bit. I see a black/red, black/blue, and black. I am assuming the red is 12v source, the black is ground, and the blue is the sensor signal. Problem is, I lose this wire in the loom in front of the seat and cant seem to find it coming out.
kens03
28
Aug 15, 2025 12:26 AM
gilbyfltr
May 12, 2020 06:18 PM
pikeysxtcob
Mar 8, 2020 08:51 AM
Ciadric
EVO
15
Aug 11, 2013 04:07 PM
sledhead140
Aug 28, 2011 10:10 AM
