Buffeting
I am 6 foot 3 inches.
The HD quick detach windshiels beats my head around something fierce.
Right now the shield is about nose level.
If I raise my head while riding, the Buffeting does not stop. If I duck it gets much better. However this makes me look thru the windshield which from what i read is wrong.
I typically ride without a shield but the wife is on me to put one on there when she rides. So I need to solve this.
Based on my ducking solving the problem, it seems that I need a taller shield, but that will put it above eye level.
It seems that if I go shorter I might have to go way shorter.
What about a Memphis or a recurve shield? The recurve in particular looks interesting.
My windshield is okay under 45mph but gets really bad above it. Which is when it's needed most.
@ the OP:
there is a possibility to reduce the buffeting: on the two upper quick detach features, you can adjust the fittings, putting the WS a little more vertical. unscrew the two allen screws , adjust the WS, tighten the two allen screws. done.
If the WS, with the wind pressure, comes back to the previous position, try to put something (nuts & bolts) between the WS and the brackets to keep the WS as you want it.
Someone here has built specific brackets to put there in between, to put his WS on a more vertical position, I hope he will chime in..
