Long Pause when starting
Old Sep 18, 2012 | 11:15 PM
Knights2TheEnd's Avatar
Knights2TheEnd
Default Long Pause when starting (Problem)
Sometimes (1 out of 10 times) when I try to start my bike, it has this long (3 to 4sec) pause when I hold down the ignition (start button). I can feel as though the bike is "building up or being held back " during this pause but it doesn't really make a sound besides that. Do you guys have a clue what it might be? The battery is relatively new and it keeps a charge very well and all connections to the battery are nice and tight and smeared with dielectric grease.. can it be due to the bike being flooded? After this pause, usually I can hear the ignition go off and everything is fine. Sometimes I have to give it some throttle while holding the ignition
Old Sep 18, 2012 | 11:34 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Dead spot in the starter motor?
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Sep 19, 2012 | 05:40 AM
Knights2TheEnd
Possible, thank you for the reply. Do you kn how I could test that
Old Sep 19, 2012 | 05:43 AM
renegadenz's Avatar
renegadenz
6th Gear
every buell i have ridden did that exact thing, always started though, buggered if i know why though.
Old Sep 19, 2012 | 06:09 AM
Knights2TheEnd
Yea, its always starts which I am thankful for but still want to understand whats happening
Old Sep 19, 2012 | 07:13 AM
1200Cdriver's Avatar
1200Cdriver
You can eliminate that pause which happens when the first compression stroke is starting at the point the starter engages. It will do that more and more as the battery gets old and tired. Simply put the bike in 2nd gear, pull the bike backwards until you hit a compression stroke with the engine turning backwards, it gives the starter a head start by getting the flywheels rolling before it cones to the next compression stroke. No baloney.
The pause is a hesitation while the compression leaks off the first compression stroke. Its more likley to do it if you start the bike with the clutch pulled and in gear, especially if the engine is cold on the first startup of the day.
Old Sep 19, 2012 | 07:34 AM
cHarley's Avatar
cHarley
The problem can also be caused by any of the battery cable connections having a high resistance, which is usually caused a dirty/loose connection, or the crimp lugs connectors on the cables becoming loose on the cable.
Old Sep 19, 2012 | 07:50 AM
1200Cdriver
Very true, my battery is now 5.5 years old and showing signs of getting sluggish, what day is it going to lay down, that is the question. Do you play it safe and get one or try to finish out this season. I am not asking this question here, its just on my mind. The Battery Tender+ still brings it to full charge in about 20 minutes after sitting a couple of days.
cHarley, I keep all the connections coated with High Dialectric grease, I take them loose now and then to clean them and get the grease inside/between the connectors. So far, no green connections.
CJHD
Jul 18, 2019 11:09 AM
trike1946
Oct 15, 2018 03:29 PM
bjc
May 23, 2017 02:28 PM
leachman
May 2, 2015 08:20 AM
tidefan60
Aug 7, 2010 03:25 PM
