Installing 4" Risers
Old Oct 29, 2012 | 06:02 PM
cooperk851's Avatar
cooperk851
Default Installing 4" Risers
I am working on installing a set of 4" risers that have a 1" pull back on my bike. Is it necessary to purchase a longer brake line or any anything else in order to install these?
Old Oct 29, 2012 | 06:46 PM
nc883's Avatar
nc883
It depends on what size risers you currently have as well as what type of bars you have. You swapping bars too? I went from 2" straight risers & buckhorns to 4 1/2" pullbacks and drag bars and had to buy a shorter brake line.
Need more info.
Old Oct 29, 2012 | 06:50 PM
cooperk851's Avatar
cooperk851
I have a 2008 883xlsportster with the stock 2" risers and 1" drag bars
Old Oct 29, 2012 | 06:53 PM
nc883's Avatar
nc883
How much slack do you have in your line AND cables?
Old Oct 29, 2012 | 07:03 PM
cooperk851's Avatar
cooperk851
After mocking everything up I have none everything is tight. Way to tight
Old Oct 29, 2012 | 07:11 PM
nc883's Avatar
nc883
There ya go....
Old Oct 30, 2012 | 01:21 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
I used the stock clutch cable with 16" apes.
If you want to save some $, pull your clutch cable off the downtube and (if you have forwards) run it over the shift bracket, it is long enough then. Only need new brake line.
Oh, I think the clutch cable is entwined in the triple trees, get it out of there too, gives you a lot more room.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
lowend73
Jun 29, 2013 05:48 AM
nc883
Aug 5, 2012 02:29 PM
CatalyticCarbon
Mar 19, 2012 10:32 AM
Unibomber
Jun 25, 2006 08:06 PM
Unibomber
Jun 25, 2006 06:23 PM
