motor swap
Old Nov 11, 2012 | 06:21 AM
warking's Avatar
warking
Question motor swap
will an 89 motor drop straight in to a 93 ?? my 5spd dropped a valve and i chewed a piston. i want to drop the 89 motor in just to get her back on the road so i can take my time re-building the 5spd.
Old Nov 11, 2012 | 07:31 AM
Gpsjr10's Avatar
Gpsjr10
I think it will fit right in. 86 to 93 should pretty much be the same.
Old Nov 12, 2012 | 10:18 AM
1984_FXRT's Avatar
1984_FXRT
Biggest thing to be concerned about is that I *think* the 89 had a different clutch actuation mechanism - (like the early Ironheads) - as well as a chain final drive.
You may need a different clutch cable to alleviate this issue.
The output shaft on the 89 isn't exactly the same as the 5-spd/belt drive (1991 +) XLs, and may require a belt pulley from the earlier conversion kits.
Old Nov 14, 2012 | 06:37 AM
warking's Avatar
warking
the 93 is chain drive, so if your giving me the good oil then worst im looking at is maybe change of clutch cable. sounds good to me.
Old Nov 14, 2012 | 08:57 AM
John Harper's Avatar
John Harper
I think I read somewhere that 5 speed case is a bit different than the 4 speed, so it may not fit in the '91 up frame. I could be wrong, of course.
I still have a piston from my old VW bus with the valve head embedded in it, pretty cool conversation piece.
John
ornerycuss
Apr 20, 2021 03:33 PM
graultytc88
Aug 6, 2016 08:51 AM
brad75raiders
EVO
Dec 5, 2013 10:16 PM
docsin
Sep 25, 2012 02:04 PM
hotrod351
EVO
Jun 1, 2008 09:20 PM
