replace coil no spark
Old Nov 18, 2012 | 03:36 PM
rusty7983's Avatar
rusty7983
Default replace coil no spark
I put a screaming eagle coil on my 88 883. I now have no spark. I put the old coil back and still no spark. This bike is my salvation. I despritely need to ride to clear my head. please help!!
Old Nov 18, 2012 | 04:01 PM
xwhyz1959's Avatar
xwhyz1959
I'm assuming it cranks. Did you disconnect anything before you started working on it??
Old Nov 18, 2012 | 09:55 PM
DOMAPOI's Avatar
DOMAPOI
Check the ignition relay? Or ignition fuse?
Old Nov 19, 2012 | 04:24 AM
marine_hm@hotmail.com's Avatar
I'm not an expert by ANY means. But this is what happened to me.
I had the same problem, changed the coil, still nothing. In tracing all the electrical... I pulled out my Crane Ignition to see if I could test that. When I pulled it out, I noticed the rotor behind it was dangling. Somehow the screw that holds it in place had backed out, letting the rotor spin freely. I dabbed some blue locktight on the threads, screwed it back down. Put everything back together and she fired right up.
It's worth checking and only takes a few minutes.
Old Nov 19, 2012 | 06:22 PM
rusty7983's Avatar
rusty7983
It took me hours. I was a dumbass and missed a wire. Of the 2 wires on the + side the blue was short and had become disconnected. I got the manual, saw I should of had 2 wires and then lifted the tank and stuck it back on. Problem solved. Thanks everybody.
Bcoish
EVO
11
Apr 29, 2019 09:09 PM
Eowright
EVO
Jun 5, 2018 08:37 AM
Frito Bandito
Ironhead
11
Sep 27, 2011 12:32 PM
daholken
Mar 28, 2009 09:46 PM
Denier
Sep 11, 2006 12:31 PM
