Shock Options
Old Nov 23, 2012 | 12:58 AM
cavalier2000's Avatar
cavalier2000
Default Shock Options
So after hours of research I got completely no where.
I currently have 13 inch air shocks on lowering blocks lowering it 3 inches. And I HATE how damn high it sits. like WAY to high for my liking.
So research gave me 10.5 burly and 10 inch licks
Now without using the blocks burly takes me .5 inch taller and licks makes me even to what I currently am.
Is there another.... shorter option, if not I have no issue keeping my lowering blocks.
I like the look of a remote reservoir or a coil over style but damn they are expensive... and LONG
Old Nov 23, 2012 | 05:39 AM
131tman's Avatar
131tman
Ultima 11" Billet chrome - hand adjustable preload - on both bikes
Old Nov 23, 2012 | 05:43 AM
cavalier2000
Other than it chrome it looks good. Kinda like stock though
Old Nov 26, 2012 | 12:46 PM
WVHogRider's Avatar
WVHogRider
No way in hell I would use lowering blocks with the 10" Lick's or 10.5" Burley's as you'd definitely be rubbing. Look in my photo gallery for pics of my '00 model with the Lick's gen I 10"s shocks.
Old Nov 26, 2012 | 01:25 PM
Afrobaron's Avatar
Afrobaron
I agree with the above poster. From everything I read on here about suspension is if you go lower than 10" on the shock you are running the risk of rubbing your tire on the fender. So putting a set of blocks on a 10 or 10.5 would put you even farther into that danger zone.
You could go hard tail struts and a spring or air ride seat, which might get you closer to where you want to be. Or you can ditch the fender and trim up the back end to fit a lower shock.
Old Nov 26, 2012 | 01:35 PM
grbrown's Avatar
grbrown
Exclamation
If you go any lower you'll have to go rigid! Do you want any suspension?!
Old Nov 26, 2012 | 02:25 PM
kidney_bean's Avatar
kidney_bean
Yup...I just made my own fender and mounts and put it about a half inch above the tire and mounted to the swingarm, but I'm still running 11" shocks...
Old Nov 26, 2012 | 02:52 PM
JeffJA's Avatar
JeffJA
I have the 10.5" Burly shocks, pretty sure if you run blocks with them things will rub and smash.
Old Nov 26, 2012 | 03:18 PM
cavalier2000
At my current height I have plenty of room to go lower, would just need to be a stiffer shock and use some different bolts. I found some 11 inch and some 9.75 **** shocks that I like. I just need to do some measuring
Ben E
Mar 14, 2020 11:08 AM
MerloSunglo1
Touring Parts
Aug 11, 2018 02:02 PM
WVICEMAN
EVO
17
Nov 8, 2016 08:22 AM
Turbinesaint
Mar 11, 2014 09:38 AM
low_wgn
Mar 19, 2010 07:03 AM
