2006 harley xl1200c sp mpg?
Old Dec 3, 2012 | 05:28 PM
shanvhere's Avatar
shanvhere
Default 2006 harley xl1200c sp mpg?
I did a test, cause I notice I do not get the miles/gallons of gas I use. I drove it 82.4 miles and just put 3.3 gallons, before the tests I always topped it off but on average I only get 24 miles per gallon, is that normal?
Old Dec 3, 2012 | 05:30 PM
shanvhere's Avatar
shanvhere
I am also a big guy 6'1" 330
Old Dec 3, 2012 | 05:37 PM
ev0lution7's Avatar
ev0lution7
i would say you are running too rich or there is another problem because with my wife and i on the bike (about YOUR weight) we get between 44-50mpg we can go about 170miles before needing reserve... (about 3.5 gal)
things to check!
1. Intake seal leak...
2. exhaust leak...
3. problems with your carb... needle seat worn... float valve worn... bad diaphram.. clogged Emultion tube..
check those things out and report back
Old Dec 3, 2012 | 06:28 PM
shanvhere's Avatar
shanvhere
things to check!
2. exhaust leak...
Does it mean anything that I get a lot of back fire on the carb?
Old Dec 3, 2012 | 08:27 PM
Big_Redneck's Avatar
Big_Redneck
Yes, backfiring through the carb is usually timing issues or severe carb issues...
Old Dec 3, 2012 | 08:28 PM
Big_Redneck
Shan, Im in Houston as well, Katy area to be precise. I wouldn't have a problem taking a look at it for ya sometime if you want.
Old Dec 3, 2012 | 08:38 PM
883Frankenbike's Avatar
883Frankenbike
I took a day trip yesterday. About 200 mi. I have an 06 883 and am 6'1" and 270. (Fat guy on a little bike- is my theme song.) I got 56 mpg crusin the back roads at 50 to 60 miles per hour. Yepper. Somethins not right. I'd get a new tuners kit from CVP or something similar that you might like. There are a ton of them out there. Cleaned my bike up and she runs like a champ now. Good luck man.
Old Dec 3, 2012 | 08:52 PM
wanabe's Avatar
wanabe
clearly a need for carb adjustment... change your air sucker and pipes, then retune the carb-
at that point you have a choice. better mpg (set it more lean) or better smiles per gallon (set it richer). I chose the later!
Old Dec 3, 2012 | 10:58 PM
shanvhere's Avatar
shanvhere
Well time to do some research as I am a new rider. And Big_Redneck that would be a good idea but I think you live to far from me and would hate for you to truck your way for me buddy.
Old Dec 4, 2012 | 12:09 AM
ev0lution7's Avatar
ev0lution7
Backfire in the carb is not good!
I would check those things first to see if you have a problem.
