Can you take 10 inch rigid struts and use them with lowering brakets?
I just put the struts on my bike and its not giving me the fender to tire gap that I want. Im just curious if I can add back my lowering kit to bring the rear fender down lower to the tire. Would this be bad or what?
Don't use brackets! I snapped some with shocks. Rigid struts will bust them for sure! Re-mount the fender to the swing arm is your best bet. Gotta do some fabrication to make it work but that's the fun part!
I've never looked into the lengths that are available, however it would not be that hard to fab up some to the right length. Looks like it's just some steel rod with some tubing welded on to use as the mounting points.
You could make them yourself if you can weld, or you can pay someone. A skilled welder could do it no problem. Send them off to powder coat and you will probably still come in under the $100 or so that many of them go for.
Or I could just take the ones I have and shorten them up and reweld the bolt hole part.
The picture below is a guy running our Beefy Struts with some Billet lowering blocks. I personally don't know how comfortable I would be doing the same, but have had no report from him of a failure and it's been a couple of years.
Also, have asked before, has anyone ever seen a billet lowering block fail? I have seen the welded ones fail.
Kevin I want my rear fender to sit on my tire just like that! My lowering braket is a welded not a billet , if i did it I guess I would need to buy a billet bracket.
