My VIN # got Powder Coated... what to do?
Old Jan 1, 2013 | 09:10 PM
Justin2Wheels's Avatar
Justin2Wheels
6th Gear
Default My VIN # got Powder Coated... what to do?
Hello Everyone,
Im a newbie to the forum.. ( it was recommended by a friend )
So here is my dilemma..
Im a happy owner of a Sporty 883 that has been incredibly good to me..About 6 months ago right before I moved to CA from VA, I took my bike apart and decided to give it a well deserved face-lift
I took the frame to get powder coated and clear-coated and I got the frame back just a day before leaving VA.
I was really happy with the look of it but now Ive put the bike back together with some upgrades, a 1200 conversion and cosmetic stuff.. and I just noticed that the VIN# in the neck got covered by the powder coat and you can not see it
if you brush your fingers in there you can feel it but cant see much.. If you use a flashlight in certain position you can sort of identify the last 13 numbers in there (so its definitively my frame)
Now, the question here is what to do? How can I take off the powder coat just in that area or what are my options?
The bike is finally running and i have to do the DMV transfer and out of state Reg so I dont know if they want to inspect the bike and or if I get pull over I'll be in trouble.
Has this happen to anyone before or Im a lucky one ...
Any ideas will be appreciated
thanks
J
Old Jan 1, 2013 | 09:15 PM
Iceman24's Avatar
Iceman24
I'd say, as long as you have the original title w/VIN, you should be able to prove it's the same frame - if identified/questioned. I'd leave it alone and give it a try (registration)...worse thing is they have you register as "custom" bike vs. original. Chipping away the power coating will probably look bad & even cause more questions to arise. Good luck!
Old Jan 1, 2013 | 09:18 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
Sticker isn't important. VIN should be stamped on the neck.
Old Jan 1, 2013 | 09:20 PM
Mark_H's Avatar
Mark_H
Subscribing to this. I'm wondering if a solvent and steel wool would do it, but how to isolate the solvent to not ruin the surrounding areas.
I know there is at least one guy on here that does a lot of powder coating and he will probably see this thread. Hopefully he can help. I can definitely see it being a problem.
Old Jan 1, 2013 | 09:39 PM
Justin2Wheels
6th Gear
It isn't the sticker...(that one was lost long ago) what got cover were the actual stamped #s
Old Jan 1, 2013 | 09:44 PM
QC's Avatar
QC
Somebody call the cops!!!!! Before he gets away!!
Old Jan 1, 2013 | 09:47 PM
Justin2Wheels
6th Gear
Excuse me ???
Old Jan 1, 2013 | 09:50 PM
Justin2Wheels
6th Gear
Originally Posted by Mark_H
Subscribing to this. I'm wondering if a solvent and steel wool would do it, but how to isolate the solvent to not ruin the rest
When you mention a solvent, what type of solvent might go through powder coating ?
Old Jan 1, 2013 | 10:29 PM
baka1969's Avatar
baka1969
Originally Posted by Justin2Wheels
Excuse me ???
He's just joking around. lol
Old Jan 2, 2013 | 02:20 AM
cavalier2000's Avatar
cavalier2000
How thick did they put on the powder? I have two coats on my frame and you can see it clearly.
BUT you can take a small scribe and pick the powder out of the frame.
Also you cleared over powder?
