I have a 96 sportster custom 1200, i had to replace my front belt pulley and when i was doing that i wanted to replace the primary and timing gaskets.
Now it won't start up, i have a manual and i've done everything it say but i must be doing something wrong or missing something.
I have a 96 sportster custom, i had to replace my front belt pulley and when i was doing that i wanted to replace the primary and timing gaskets.
Where does the problem start? Got power? Does it try to turn over?
1) Are you certain you got the cams lined up properly - w/the dots aligned on all 4 w/the front piston at TDC?
2) Did you properly align the timing rotor when you reinstalled it? Reconnect the module connection?
I'm pretty sure i lined them up properly, i'm going to take off the cover tomorrow and double check them. How do you know when the front piston is at TBC?
I did align the timing rotor when i reinstalled it, i didn't disconnect the module connection.
The best way to know is to pull the timing plug and line up the timing mark on the flywheel. then - you need to make sure you've got the #2 cam ( the one you probably yanked out by not first pulling the ignition module and rotor like the factory manual instructs you to do) lined up with the alignment on the pinion gear, and the #1 and #3 cams, while also making sure that the #4 (rear exhaust) cam lines up.
You need to be at face level looking straight at the cams, and not sitting on your stool looking down, or you'll misalign them by a tooth.
What did you do to take the valve spring tension off the lifters? There are some horror stories on this site about pulling the cam cover off before pulling the rocker arms (I think) to relieve pressure on the lifter/cam lobe area. Be careful when you go back in.
