Later Model Headlamp
Old Jan 6, 2013 | 03:31 PM
roundy's Avatar
roundy
Default Later Model Headlamp
Would you be able to fit one to an earlier Sporty?? Like a 2006 Headlamp on a 2001...?
I don't imagine the plugs are going to be the same but I imagine you could splice it in??
Old Jan 6, 2013 | 08:03 PM
groverhd's Avatar
groverhd
Sure you could. i just put a 7" on my 48. i had to splice it but it works
Old Jan 7, 2013 | 08:41 AM
roundy's Avatar
roundy
Cool, i like the look of the clear glass on the later sporties.....unless you can just buy a H4 insert that is clear....?
Old Jan 7, 2013 | 11:29 AM
cHarley's Avatar
cHarley
You can, but just replacing the lens will cause the light will not be dispersed properly. You'll likely wind up with more of a spot light than a flood light.
The headlight bulb, lens and reflector are designed to work as an assembly.
Old Jan 7, 2013 | 01:07 PM
roundy's Avatar
roundy
That's what I am talking about, you can buy the whole assembly that goes in the lamp metal housing - was just wondering if anyone knows of a clear glass one...
Alleyn
Aug 27, 2012 07:41 AM
Kabear
EVO
Mar 25, 2012 04:53 PM
SwissMiss
Apr 21, 2010 07:39 PM
williamfrog
Nov 20, 2008 05:28 PM
06DEUCE
Jun 6, 2008 08:31 PM
