Iron 883 Observations
1. Rear view mirrors can't be positioned to see behind, only out to the side. Must have something to do with the handlebar type that is installed.
2. Higher level of mechanical/valvetrain noise than I hear with my Low Rider. Maybe because I have a full aftermarket exhaust and because of the differences between a Twin Cam and an Evo motor.
3. Tough to find neutral; either going from first to second or second to first. It never really wanted to drop in easily. It took numerous attempts to get it to slip into neutral.
Will the valvetrain/mechanical niose decrease somewhat after break-in?
Will the problem with finding neutral not be as pronounced as she wears in?
Thanks!
I picked up my bike with 1500 miles, I've only rode it once so far due to the weather but on my way home I noticed the noise as well. Makes me feel better you heard it also. Maybe thats just how the motor is?
Valve train/topend noise is business as usual with the sporty. Best thing I've found for that is louder pipes. At idle in the driveway after a ride you could swear it's falling apart but she always starts & runs great every day.
Thanks!
2) I don't have anything to compare the noise to, since my Iron is my first bike, but I have V&H Short Shots on it, so mine may not be the best to compare to noise-wise.
3) YES! I have trouble finding neutral quite often - I thought it was just me! It does seem to be getting better as time goes on, so maybe I'm just getting used to it.
Be safe out there!
When you do your 1K service change to synthetic oils and adjust your clutch per specs when its cold. It will shift just as well as your low after that.
