Suspension confusion
Old Jan 27, 2013 | 08:06 AM
Mac10's Avatar
Mac10
Thanks for the info.
Old Jan 27, 2013 | 01:15 PM
xwhyz1959's Avatar
xwhyz1959
Originally Posted by DK Custom
Sorry to say, the best adjustment for stock shocks on a sporty is to replace them.
Take-off HD Touring air shocks can be had on ebay for around $100, and they ride very nice, regardless of your weight.
+1 on that. I wish I would have done that upgrade way sooner than I did.
Old Jan 27, 2013 | 05:58 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Originally Posted by edgeofinsanity
There are shorter air shocks (12") available that you can run as direct repacements. Some guys run the 13" and deal with a little higher seat height, or you can use lowering blocks to get back to stock height. I went from 12" to 13" with lowering blocks, and while I have not been able to put many miles on since the change, the 13" shocks seem to have a bit smoother ride than the 12" shocks. The air shocks seem to not give much improvement to smaller guys, it seems like if you are under 170lbs, they are not much of an improvement.
The take off RoadKing or StreetGlide air shocks are probably your lowest-cost option. They are adjustable somewhat by adding air. I probably have $150 total in mine with the lowering blocks and air pump.
The aftermarket shocks, like the Ohlins that grbrown is talking about will cost you quite a bit more, but will give an even better ride. I've ridden on a bike that was similar to mine that was fitted with Progressive 412s, the lowest cost Progressive shocks, which were a lot better than stock, but equal, or even a little worse riding that my air shocks. Lots of choices out there, it really comes down to what you want to spend.
You'll find that once you upgrade the rear shocks, you'll feel how bad the front forks dive and bottom out, but that's a whole different topic.
Yeah, I had 12" air shocks, went to the 13" much smoother ride. Then when I put the lowering blocks on, and even smoother ride. I'm 185 and was running 5 psi before the lowering blocks, now with them am running 18 psi., very nice ride.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Jan 29, 2013 | 03:14 PM
mariartw's Avatar
mariartw
Is it PN 54000008 that can be swapped for our OEM shocks?
EdandGrace
Aug 17, 2013 07:46 PM
iamrockinrich
Nov 29, 2012 06:12 PM
sioux565
Jan 22, 2012 03:35 PM
StreetGlider57
Mar 26, 2011 08:34 AM
dkfxr
EVO
Sep 12, 2009 02:49 PM
