shocks
Old Aug 15, 2013 | 08:17 PM
EdandGrace's Avatar
EdandGrace
Default shocks
OK, so I have done a number of searches and found good info but not enough to make a decision. let me know if there is a thread that answers what I want. 13 SG. 150 lbs and ride 95% solo. Have stock shocks and have put them at 10 to 20. Doesn't matter, I feel every bump in the road. What should I change to in order to have a better ride? Thanks.
Old Aug 15, 2013 | 09:11 PM
'05Train's Avatar
'05Train
JRI from Motorcycle Metal and be done.
Old Aug 15, 2013 | 09:36 PM
XARAN's Avatar
XARAN
Ditto.You have to change the shocks.
The stock shocks are way over sprung for a lighter rider like you, Even with 0 psi you wont be able to adjust in any sag on stock HD air shocks, they will be hard and topped out most of the time. Im about 205 -210 and the stock shocks coud not be properly adjusted for sag at my weight and 0 pressure. The rule of thumb os with the rider on the bike they should sag about 1/3 the length of travel so on HD 12" shocks that have 2" of travel you should get 1/2-3/4 " sag and Ill bet they dont move with you on it.
Look into what you can afford JRI, Ohlin, Terry Works or Proressive all will be an improvement, I MO from best to better.
Old Aug 15, 2013 | 10:37 PM
mkguitar's Avatar
mkguitar
yes, start with air pressure adjustments...for me 7 to 10 PSI at 235# with riding gear and about 15 pounds of crap forgotten in my saddlebags
you have the 12" shocks, the ultras etc have 13" shocks...so 50% more shock travel and more time for that travel to take place= smoother ride
you neither want to bottom out or "top out" the shocks
if that doesn't work then you may be looking at dropping cash on premium aftermarket shocks
mike
Old Aug 16, 2013 | 06:06 AM
bikerlaw's Avatar
bikerlaw
I run flat zero solo. No air pressure at all in the shocks. I add air when the wife gets on. I'm about 185 lbs.
Old Aug 16, 2013 | 06:09 AM
Iceman24's Avatar
Iceman24
Been doing the same research and almost had a set of Progressive 940's from another forum member (missed opportunity). With my budget - seriously considering new set of Progressive 944's w/std springs...little over $500, but sounds like x1000 improvement over stock springboards on my FLHX.
Old Aug 16, 2013 | 06:59 AM
HDV-GLIDE's Avatar
HDV-GLIDE
+1 on that...Spend the money once and don't look back.....
Old Aug 16, 2013 | 08:54 AM
Def Mute's Avatar
Def Mute
Just put some more weight on...
Another 150 lb should do it. Grow a beard and, if ya have to, dye it gray. Then you'll look like the rest of us!
Old Aug 16, 2013 | 12:42 PM
EdandGrace's Avatar
EdandGrace
Thanks man! Got the gray beard, not sure about the extra 150.
Old Aug 16, 2013 | 01:07 PM
Deckman's Avatar
Deckman
I have had the JRI Type A shocks for a couple months. I do not have bottoming out problems, but these are not plush soft riding shocks. I would say they are a more performance riding shock similar to the ride of a sport coupe car. My stock shocks bottomed out often and the ride was very uncomfortable.
