Brake Fluid Question
Old Jan 28, 2013 | 07:37 AM
1Hellrazor's Avatar
1Hellrazor
Stage II
Default Brake Fluid Question
Hello everyone, my question is....do I have to run a "special" kind of brake fluid in the back cylinder on my 2006 Sporty? Or can I just buy a "regular" can from any parts store? Thanks in advance.
Old Jan 28, 2013 | 08:37 AM
nc883's Avatar
nc883
As long as it is the particular type, specifically the DOT #, you'll be fine
Old Jan 28, 2013 | 08:59 AM
cHarley's Avatar
cHarley
There is no "regular" brake fluid, it comes in several flavors known as DOT x, where x equals the fluid type. The correct fluid type is imprinted on the top of your master cylinder covers, it should be DOT 4 or DOT 5. Harley switched the type of fluid they use from DOT 5 to DOT 4 around 2006, so check your caps.
DO NOT mix fluid types, they are not compatible.
Edit:
For model year 2005, the FL platform changed to DOT 4.
For 2006, all models except the Sportster went to DOT 4.
For model year 2007, the Sportster changed to DOT 4.
Old Jan 28, 2013 | 09:00 AM
ev0lution7's Avatar
ev0lution7
Look at the brake res cap it "should" say Dot 5... Not dot 5 is not compatible with dot 3/4 that u use for your car...
Old Jan 28, 2013 | 11:46 AM
DOMAPOI's Avatar
DOMAPOI
As stated above, check your reservoir cap for the correct DOT number. If for some reason your cap was replaced with one that does not have the DOT type listed, check your service manual or owners manual. DO NOT ADD ANYTHING UNTIL YOU MAKE SURE IT IS THE CORRECT ONE!!!!!!!!
Old Jan 28, 2013 | 12:07 PM
1Hellrazor's Avatar
1Hellrazor
Stage II
Thanks everyone, I'll check the cap to see which DOT # the old girl uses. As always, this is still the greatest place for Harley advice, tips and ****. Thank you fellers again, I greatly appreciate it.
98hotrodfatboy
EVO
34
Jul 12, 2019 07:07 PM
Geoff
Feb 3, 2013 02:47 PM
mayo
Wheels/Tires
11
Dec 26, 2011 04:42 PM
Fiddler
Jul 6, 2008 07:42 AM
bigjako
Oct 18, 2007 05:30 PM
