Wheel alignment
Old Feb 11, 2013 | 12:30 PM
Jackie Paper's Avatar
Jackie Paper
Does your's look like this 2009
Old Feb 11, 2013 | 12:33 PM
gargoyle13's Avatar
gargoyle13
Can't tell, I'm on a iPhone, can't expand photo.
Old Feb 11, 2013 | 12:49 PM
gargoyle13's Avatar
gargoyle13
Yep, pretty close but I can't see your adjuster.
But the rear tail piece that is welded to the arm, that has the slot and axel, look like mine.
Old Feb 11, 2013 | 02:29 PM
Jackie Paper
Not my bike. Why I posted it. I could not see the adjuster your were talking about or any adjuster either.
Old Feb 11, 2013 | 02:32 PM
gargoyle13's Avatar
gargoyle13
I believe the adjusters are covered up by the after market shock bracket.
Old Feb 11, 2013 | 02:38 PM
1984_FXRT's Avatar
1984_FXRT
Are the adjusters on the newer XLs somehow permanently affixed to the bike? On every HD I've worked on, the adjusters are a block that fits into the end of the swingarm, w/an eye-bolt through which the axle is installed.
Old Feb 11, 2013 | 03:08 PM
gargoyle13's Avatar
gargoyle13
Yes, the adjusters are a fixed item on the swing arm.
They consist of an eyebolt, locknut, with just a hole drilled thru the back of the cast metal axel slot bracket. The bracket is one piece welded to the swing arm.
Old Feb 11, 2013 | 04:18 PM
1984_FXRT's Avatar
1984_FXRT
OK - how would you get the eyebolt out to replace it if it has excessive wear? Hmm - I've gotta go look at one of these a bit more closely to get my head wrapped around it.
Old Feb 11, 2013 | 05:54 PM
gargoyle13's Avatar
gargoyle13
The eyebolt is removable, it is removed from the wheel side of the swing arm.
blackflame
Sep 11, 2013 02:49 PM
Alleyn
Mar 7, 2013 07:07 AM
HDF Tech
Aug 14, 2011 06:42 AM
TARTAN2
Feb 8, 2008 09:03 PM
igniter
17
Oct 6, 2007 11:06 PM
