Please help! rear brake problem!
Old Feb 18, 2013 | 02:58 PM
playpattwhatup's Avatar
playpattwhatup
6th Gear
the brake light does not stay on
Old Feb 18, 2013 | 03:46 PM
Jackie Paper's Avatar
Jackie Paper
Drive it slowly on a back street to brake and release a few times. The lift the rear and spin tire. If it just hits and spins and hits with just sound but no real drag that is pretty normal. Both mine do it and my rotors run within .002 or so. I always hear my front wisping while backing out of garage
Old Feb 18, 2013 | 05:52 PM
JeffJA's Avatar
JeffJA
i rear rotor always has a bit of squeek when rolling back and fourth in the garage also.
Old Feb 18, 2013 | 06:34 PM
John Harper's Avatar
John Harper
If your brake pedal is now set lower, you have re-assembled the linkage incorrectly. If your brake system worked before, there is no reason for it to "lock." Also, highly unlikely you suddenly have a warped rotor. This mission was supposed to be a simple exhaust install, right?
Now, rolling it around and hearing a "squeak" or two is totally normal. If you have not ridden you bike for a while it will maybe even squeak a bit when you first ride.
Please buy yourself a Factory Service Manual, you can see what the assembled parts are supposed to look like. From now on, maybe you should take a photo of the area you are working on beforehand, so you will have a point of reference.
Good luck.
John
Joker_Hal
Dec 8, 2018 12:02 PM
Lonny Rae
May 26, 2017 11:59 AM
Calvin1989
Jun 26, 2015 11:54 AM
playpattwhatup
Wheels/Tires
Feb 18, 2013 12:42 AM
HDmikie
Oct 15, 2012 08:32 AM
