Starting problems
Old Feb 23, 2013 | 05:31 PM
jerryw618's Avatar
jerryw618
Default Starting problems UPDATE
hi there ok my 07 883Low is not starting ,it had been running fine, but for the past week or 2 its been acting up when i turn it on the blinkers flash and it wouldnt start the headliglight comes on speedo lights up, horn works but nothing happening when i hit the starter button . id turn the bike on and off a few times and straighten it up (off the jiffy stand ) and it started. Now it wont start at all . i changed the battery in the key fob that didnt help . i checked and its not showing and error codes . ill have to get some tools and check fuses and connections , but any ideas
its at the dealer they say its the tssm module gone bad, needs replaced
Old Feb 23, 2013 | 06:55 PM
Mr.Twisted's Avatar
Mr.Twisted
My '08 has been acting the same way. I haven't fired it up for about a month. It almost seems as though the security system has forgotten about the key fob. Battery is good. what I did was disable the security system with my number code, then it started right up. But prior to that it was blinking all over the place and the starter was not working.
I moved it around in the garage a little, and now it seems to be acting O.K. I'm about to dig into my winter project which will have me removing the rear fender, and electricals, so it will be a good chance to make sure everythings tight. If you figure anything else out let me know, I'm curious to know what's happening.
Old Feb 25, 2013 | 08:02 PM
shwimmy86's Avatar
shwimmy86
My 08 is doing it as well...rode it no more than 3 days earlier, go out n try to start it...nothing. moved it out of the garage n it fired right up. Went out again just yesterday, and the same exact thing! From other threads that I have read today I think its pretty common problem with 08's
Old Feb 26, 2013 | 06:32 AM
jerryw618's Avatar
jerryw618
well i started looking things over , i changed fob battery again, checked fuses all ok , swapped relays still nothing , so i tested my battery it showed 11.2 volts. i pulled it and put it on a charger ill go get it later this morning and install it , hopefully it will solve my problems. ill keep you posted on my results .
Old Feb 26, 2013 | 07:51 AM
wtb3886's Avatar
wtb3886
HD 07 883 Low Not Starting problem
07 883Low is not starting up, When I turn it on the blinkers flash and it wouldn't start.
1st off the blinkers flashing is telling me that you have a security ISSUE.
If your sure that you have no DTC Fault codes stored on your speedodomer,
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
Do you have your manual for your bike?
Your security system is not seeing your FOB, at what point is your flashers going off?
Old Feb 27, 2013 | 06:20 AM
jerryw618's Avatar
jerryw618
1 im sure there are no codes , i checked for them severaltimes it comes up none on each section
2 yes i have the manual ive been thru the troubleshooting procedures and didnt find anything that helped
3 signals flash as soon as i turn on the power either accessory or ignition on and turn on the on/off switch , but they will also flash if i move the bike around.
i actually have 2 fobs and i tried the second one also , with a new battery installed . same problem.
Old Feb 27, 2013 | 06:34 AM
Iceman24's Avatar
Iceman24
@ 11.2V, your battery's extremely low so (hopefully) this will do the trick. Is this the original battery in your bike? If so - you got good life out of it & could be time for a new one.
Old Feb 27, 2013 | 06:49 AM
jerryw618's Avatar
jerryw618
NOPE didnt work i had the battery on a charger when done i checked it , it was at 12.58V i reinstalled it and same problem, this is not the original battery its only 2 years old its a stock battery from dealership
Old Feb 27, 2013 | 07:26 PM
notofthisworld's Avatar
notofthisworld
I have that problem a few times. The first time it was the starter relay, the second time it was the system relay. Both are in the fuse box. Both cost $8.00 a piece. The cheapest fix I've ever had on my sporty.
I would start there, then if that does not work. Check all your battery connections.
Old Feb 27, 2013 | 07:57 PM
cHarley's Avatar
cHarley
2007 Sportsters are well known for having chronic moisture/corrosion problems in the fuse-block/relay area.
Remove all of the fuses and relays. Clean the contacts on the fuses and relays, and then coat the contacts with dielectric grease and reinstall. You can find the dielectric grease at any auto parts store.
