White smoke and noise from the starter when starts
Old Mar 13, 2013 | 01:06 AM
headbanger8383's Avatar
headbanger8383
Default White smoke and noise from the starter when starts
Hello guys!
i have a strange problem with my 94 sporty. when it is hot its usually starts good.
after several hours brake (or morning) it start with "crack" noise and white smoke and burned electricity smell comes from the starter area. i reassembled the starter , tight the connections... any ideas guys?
Old Mar 13, 2013 | 05:48 AM
headbanger8383
May be someone had the same issue?
Old Mar 13, 2013 | 06:03 AM
DrewBone's Avatar
DrewBone
From: In the foothills of southwestern NC - US of A
The "crack" noise and associated smoke is usually generated from an electrical arc created from a loose positive electrical connection, either at the starter or the battery when the starter pulls a full [current] draw on a cold battery. If both these connections are tight and the cable/connectors are in good shape then it may be the positive post of the starter solenoid...is it loose? It's common to loosen and overtighten this post and even damage the solenoid itself if you don't double wrench the connection when tightening or loosening it for whatever reason, as it's only plastic. If it's loose it may be arcing internally, or, your starter is "starting" [bad pun I know] to go...
=8^)
Old Mar 13, 2013 | 06:10 AM
headbanger8383
Thank you DrewBone! i will check it!
Old Mar 13, 2013 | 06:26 AM
Rog48's Avatar
Rog48
Smoke makes electrical things work. You let the smoke out.........it quits working. Harley sells smoke, follow the manual (you did buy one didnt you?) and put the smoke from harley back in the starter...........you should be good to go.
Old Mar 13, 2013 | 06:32 AM
DrewBone's Avatar
DrewBone
=8^)
Old Mar 13, 2013 | 07:53 AM
John Harper's Avatar
John Harper
Classic!
John
Old Mar 13, 2013 | 07:58 AM
Van Buren's Avatar
Van Buren
maybe your Harley just decided the next pope
Old Mar 13, 2013 | 09:51 AM
DrewBone's Avatar
DrewBone
HA!! I was just thinking earlier...could you imagine if the camera was aimed at the wrong smoke stack? It could instead be that:
The black smoke billowing out is a sign that the burner unit on the boiler needs more air?
And if white smoke was billowing out, that means a few nuns were smoking cigarettes under the smoke hood in the kitchen?
'Boggles the mind!
=8^)
Old Mar 13, 2013 | 11:50 AM
kraznos's Avatar
kraznos
Army bike guy, you look huge on your sporty, rock on.
