Vac vs Gravity Petcocks
Old Mar 19, 2013 | 09:39 AM
CaptainCalf's Avatar
CaptainCalf
Default Vac vs Gravity Petcocks
I searched but didn't find anything, so please help me out here. I've got a '99 Sporty that's got some mods and I have a '94 peanut tank for it. Do I need the vacuum actuated petcock or can I just use an old school gravity petcock? I know the '99 had an OEM vacuum petcock, but not sure why? Any help and advice would be greatly appreciated
Old Mar 19, 2013 | 11:45 AM
John Harper's Avatar
John Harper
Should work fine, gravity has been around a lot longer than vacuum. Just make sure you cap off the open vacuum port so the VOES still functions properly. Just have to remember to turn it on and off, pretty simple for most humans.
John
Old Mar 19, 2013 | 11:52 AM
CaptainCalf
John
LOL, thanks John! I think even I can remember to do that
Old Mar 19, 2013 | 12:05 PM
Wild Card's Avatar
Wild Card
The vac only opens the petcock for fuel flow. It has nothing to with delivery in a sense.
If you don't have suction on the valve port it won't open and allow fuel to gravity feed to the carb
Old Mar 19, 2013 | 12:12 PM
CaptainCalf
That's what I figured, so like Big John said above it's not needed if you just remember to turn off your fuel. The problem I've run into with vac assisted petcocks is the diaphragms eventually always give me trouble. Eliminating that from the equation with a plain ole gravity petcock should always work as long as I remember to turn it on
chasenfins
Aug 31, 2016 06:23 AM
misfitJason
Feb 16, 2011 07:34 AM
emtjayb
Dec 17, 2008 01:15 PM
pig pin
Exhaust System Topics
Sep 3, 2008 03:13 PM
Fubba
Shovelhead
Jul 15, 2007 11:04 AM
