Help needed
Old Mar 19, 2013 | 12:54 PM
benjitellez's Avatar
benjitellez
Default Help needed
Hey guys I hope you can help me, yesterday I was riding my 07 1200c and suddenly my right turn signal stopped working:
Every time I try to activate it, the red key light on the speedometer turns on and "blocks" it, doesn't work and the red key light remains turned on. The left turn signal works fine
I figured out that if I activate the flashers, the red key light turns off, but then again I try to activate the right turn signal and it all happens again.
Do you know whats wrong?
Old Mar 19, 2013 | 01:31 PM
kraznos's Avatar
kraznos
Take the working bulb out and put it in not working
JeffJA's Avatar
JeffJA
Have you tried pulling and checking the bulbs?
Old Mar 19, 2013 | 02:53 PM
Cpz's Avatar
Cpz
1st Gear
Yeah I would try the bulbs first and then if the problem stays it is most likely in the control circuitry for the right turn signal. Might have a lose connection.
Old Mar 19, 2013 | 03:52 PM
Mac10's Avatar
Mac10
Could be the turn signal module is shot. That will cause the red key light to come own reporting it as an error. It's under your battery. Not sure if only one signal would be out with that though. But worth a look if a new bulb doesn't work.
Old Mar 19, 2013 | 04:20 PM
AjaBra's Avatar
AjaBra
I had a problem with my '07 custom where my right blinker would come on randomly or not at all. What fixed it for me was using bulb grease on the bulbs and all the connections under the tank.
Old Mar 20, 2013 | 12:47 PM
benjitellez
Thanks for your help! Yesterday I checked the bike and the turn signal worked fine, all bulbs are ok, don't know what happened
Old Mar 21, 2013 | 11:30 AM
John Harper's Avatar
John Harper
Chupacabra.
john
Tileman2692
Electrical/Lighting/Alarm
Nov 22, 2016 09:38 PM
powermanpike
Sep 2, 2011 09:55 AM
trainwreak
Aug 10, 2009 04:52 PM
BobBrousseau2002
May 16, 2009 09:27 AM
hawnstar
Dec 20, 2007 09:15 AM
