cam spacer plates
Old Mar 27, 2013 | 04:27 PM
RidemyEVO's Avatar
RidemyEVO
Default cam spacer plates
Hi
My son has a 86 Sportster and he is installing andrews cams in it. My son says the 2 double hole spacers that are between the cams and the block had the bevel side of the spcers pointing out toward the cam and I'm thinking the bevel has to go toward the block so that the cams will ride on the flat surface. Can someone that knows absolutely for sure which direction there suppose to go tell me?
Also I'm thinking the purpose of the bevel is to feed oil to the needle bearings, is this accurate?
Thanks
Old Mar 28, 2013 | 05:59 AM
cavalier2000's Avatar
cavalier2000
8. On 1986-1990 models, install both cam gear plates in
their gearcase recesses. Position the cam gear plates so the
beveled side of the holes faces toward the cams.
This is from my manual. Let me know if it doesn't help
Old Mar 28, 2013 | 07:46 AM
RidemyEVO's Avatar
RidemyEVO
ThAnkyou that defiantely helps. My son remeasured the new Andrew cams against the stock cams and found out the Andrew cams are .037 shorter so that explains the excessive end play so he will have to get some shims.
Hillsidecycle.com
Milwaukee Eight (M8)
Jan 1, 2017 02:49 AM
pat1
Sep 10, 2012 10:19 AM
klaybus
Exhaust System Topics
Jan 8, 2012 10:03 AM
sherm_100
Feb 2, 2010 08:22 PM
jaguar
Ironhead
Jan 1, 2007 09:27 AM
