Need help!!!
Old Apr 5, 2013 | 11:14 PM
rcoleman1701's Avatar
rcoleman1701
1st Gear
Exclamation Need help!!!
Have a 1991 Sportster Hugger, when i bought the bike everything ran fine until about a month or two in to it. Got up one morning and it was slow to crank then after work it wouldn't start. Bought a new battery and that seemed to be the ticket but after a few weeks it did the same thing. I bought a new stater and voltage regulator. Got the stater on after a 3 hour self taught lesson on how to do it with input from friends that ride on where it was located. When changing the voltage regulator i found a loose wire that looked as if it was broken. Found where it went and fixed it. Haven't got the voltage regulator completely on yet but will in the morning. If it still doesn't start what else could be the problem???? Please help it is killing me to see her sit on the garage when its such nice weather out...
Old Apr 6, 2013 | 12:29 AM
cavalier2000's Avatar
cavalier2000
see if that fixes the problem first then go into "what ifs" just make sure the battery is good and charged when you start out.
Old Apr 9, 2013 | 03:14 PM
rcoleman1701
1st Gear
Okay changed the voltage regulator and battery is about half charged. It will start and run while battery charger is hooked up but as soon as I take the clamps off it dies.
Old Apr 9, 2013 | 05:29 PM
bmxatv's Avatar
bmxatv
Make sure the battery is holding a charge and CHARGE IT. get yourself a battery tender too to keep the battery maintained while it sits.
Old Apr 9, 2013 | 05:42 PM
bmxatv's Avatar
bmxatv
You're duping threads dude.
Old Apr 9, 2013 | 08:12 PM
cavalier2000
Yea battery charger on while the bike is running wont tell you much. A bike will stay running with a dead battery.
Charge the battery then see if it will start
tnguyen7607@email.vccs.edu
Jan 25, 2017 12:21 PM
adamk
Electrical/Lighting/Alarm
11
Mar 31, 2015 04:22 AM
Borderman
Sep 23, 2011 10:15 AM
Booey424
Sep 19, 2011 01:51 PM
1993mooglide
Aug 22, 2009 08:32 AM
