shinko tyre/wheel conversion
A 150 tire is pushing the limit of that rim.
Many 150 tires require a wider rim.
I don't know of any 170 tire that is recommended for a 3.00 rim.
I wouldn't use a Shinko tire, even if it was the right size.
If you squeeze a 170 tire onto a 3.00 rim, it isn't going to be as wide as on correct 4.50 rim.
A Nightster rear wheel should be identical to the 48.
The 48's 32 spoke front wheel might require some spacer experimentation, for axle & rotor.
A 40 spoke front wheel from a Crossbones or Slim might be easier.
i ordered the 48 spoke wheels ;-) now waiting untill delivery....
can someone perhaps tell me what spacers i would need
'12 iron / vulcan wide glide kit / stock 48 rims
front:
left side axle spacer
right side axle spacer
disc spacer
rear:
pulley side spacer
rotor side spacer
thanks for you help, appreciate it !
chris
