Help.....Starting
Old Apr 16, 2013 | 05:20 PM
notofthisworld's Avatar
notofthisworld
Default Help.....Starting
Guys need your help. I have a 08 1200c
Today I noticed my red key light come on while riding then go out. I stopped at the store, turned the key nothing but one loud click. It did this 3 times before starting. I have a new starter and relay switch in it. It did not sound like the relay. Would the red light indicate the starter, or the stator.
Thanks in advance for your input
Old Apr 16, 2013 | 05:29 PM
rooti's Avatar
rooti
have you tried running the diagnostic codes through the speedometer?
Old Apr 16, 2013 | 06:40 PM
notofthisworld
How do you do that?
Old Apr 16, 2013 | 07:35 PM
AjaBra's Avatar
AjaBra
Originally Posted by notofthisworld
How do you do that?
It's a sticky: https://www.hdforums.com/forum/sport...odes-dtcs.html
Old Apr 16, 2013 | 07:39 PM
Mac10's Avatar
Mac10
Do you have a security system. Red key could be that.
Old Apr 16, 2013 | 07:57 PM
HOTLAP's Avatar
HOTLAP
The red key is normally indicating something to do with the security system but oddly enough there have been some posts on here about it comming on when there is a problem with the turn signal lights (pinched wire, bad bulb etc.), I think it's because the signals and security system share the TSSM.
Why did you have to replace the starter & relay on an 08 already?, if it was recent I'd be double checking all electrical connections at the battery, starter & ground points first.
widey
Jul 4, 2024 03:17 PM
Rodney Bogart
Aug 11, 2016 09:06 PM
Roadglidin27312
Aug 4, 2010 11:49 AM
Von_Zipper
Sep 10, 2008 10:44 AM
kelton3
Apr 26, 2008 10:40 AM
