Just curiuous, checked my engine oil temp yesterday after a 35 minute ride on the highway at 70-75 mph. Took a while but it topped out at about 198-199 degrees - not quite 200. Used a meat thermometer in the reservior.
Would this be an accurate representation of engine operating temp AND what is normal operating temp on these things anyway?
Oil and engine temp is greatly influenced by ambient temp and humidity. A cloudy day will also keep the temp down. On most summer days, my Ultra average around 220- 240 degs. Sound about right to me.
Yes thats normal temp, I have a 2011 48 with a thermometer oil dip stick and it does 200 degrees on the freeway 65MPH to 75MPH and 150ish around town..
Ditto. Even during the heat of a No Va summer, the dipstick thermometer on my '07 Custom usually tops out at 200F. During the winter, temps are usually 30-40F cooler.
Same temps for me on typical summer day, 85 to 90 degrees. Have an '08 883 with 1212 conversion.
When I first got my thermometer dipstick the temp would often be around 210 to 220. After I installed the PCIII it hangs just under 200 and rarely gets to 205. I don't think I'd want it any cooler than that. When cruising on 95 for an hour or so it sits right on 200 when the outside temp is above 90.
I just got a thermo dipstick dropped off by the ups about a hr ago will put it in Tuesday my 1st upgrade on my 883 iron and only 72.00' shsss a bit pricey IMO also ordered side shots,for my 2nd upgrade
Sounds about right on the temps your running. I am going to order a thermometer for my 09 Sporty but can't make up my mind if I want the anolog or digital. I am leaning towards the analog right now. They are pricey but what isn't on a Harley.
