Charging issues
Old May 9, 2013 | 08:46 AM
Dhammawheels's Avatar
Dhammawheels
Default Charging issues
Hello all,
I'm having troubles with my charging system and I'm looking for advice.
I have 2007 XL 883 5,300 miles on it.
I'm a complete newbie at this, but I'm looking forward to learning how to fix my bike myself. I have an appt. with my dealer next Wednesday, but I'd love to fix it myself and cancel the appt!
A couple of days ago after I had rev'd my engine higher than usual in neutral, the engine and battery light came on. I checked the DTO code and it came up po562 which i found to be low voltage. The battery seemed fine so it was a surprise.
Later, I took it out for a ride and the lights weren't lit, I thought it was OK but after about a 1/4 mile both lights came back on. At first the problem was intermittent. On off, on off, mostly coming on at red lights.
Next thing I noticed was, after pressing the run switch and the initial engine light went off, it would come back on again,before I turned over the motor.
Then things got worse. The lights started staying on all the time and it's not starting up as smoothly.
First thing I did was look for loose wires and found none, everything looks clean and feels tight.
Went out and bought a multi-meter and checked the battery after it had sat 24hours. it read 11.8V
Started the bike and it read 13.9 at idle.
rev'd the bike higher than idle and got no change in voltage reading.
I'm not sure if I have a bad battery or if the stator or voltage regulator isn't charging the battery.
Now the engine turns over but it seems there not enough power for it to start.
I have a battery tender coming Friday. How can i test the battery to see if it's ok?
Any advice is very much appreciated.
Steve
Old May 9, 2013 | 08:51 AM
grbrown's Avatar
grbrown
Both those voltages are low, you should be getting around 14.6 while the engine is running. Go to the DIY section where you will find tips on testing for charging problems, in the stickies of the electrical section.
Old May 9, 2013 | 10:17 AM
LVNightster's Avatar
LVNightster
Agree that those voltages are really low. You can take you battery to a local auto parts like AutoZone or a battery place and they will usually test your battery for free.
Good luck!
Old May 9, 2013 | 10:51 AM
JohnnyC's Avatar
JohnnyC
During your high rev you may have damaged a keyway on the crankshaft that now is allowing the rotor to spin freely. I've heard of this happening but I'm not exactly certain how your rotor stays in place on the crank on your ride.
Old May 9, 2013 | 01:02 PM
dustin1014's Avatar
dustin1014
i had very similar issues, took it to the dealership and they claimed it was my "aftermarket" battery. I ended up just going on Amazon and buying a replacement regulator and that fixed the issue. The regulators tend to go out very easily on these bikes. It would be best to take the proper steps to test the system, but i would be willing to bet a regulator is the issue.
Old May 9, 2013 | 03:33 PM
mrfikser's Avatar
mrfikser
I agree completely...but i would still test for a bad alternator and battery, before I just went and replaced regulator...
Old May 10, 2013 | 02:20 PM
Dhammawheels
Thanks for all the help guys.
I'm running a HD battery , I called Autozone and they said the readings they get for motorcycle batteries aren't accurate. I don't think they know how to do them at my location!
I'm going to try to do a load test on my own with starting the bike with the ignition disengaged.
Right now, I have my battery out of the bike and on the tender. Unfortunately, I won't have the relays I purchased until Monday.
I'll do the load test on the battery when I get home from work.
After that I'll continue to test the Regulator and Stator
But.............
...................I was wondering....... since when I rev the motor I get no increased voltage reading from the battery, does that mean there are definitely problems with either the Stator or Regulator?
Old May 10, 2013 | 03:02 PM
cHarley's Avatar
cHarley
But.............
Not necessarily. Contrary to a post above, Harley calls for the charging voltage measured at (across) the battery terminals when the bike is at a fast idle or above, to be between 13.5 - 14.8 VDC.
The 13.9 VDC you measured, should be adequate, assuming that the stator & regulator are supplying enough amps (current).
If you are still running the original (07) battery, I would replace it. Some folks claim longer life than 5-6 years, but most of those live in cooler/colder climates where heat is not a factor and the bike sits winterized 6 months a year on a Battery Tender.
I live in a hot southern climate and have yet to get (in 90,000 miles) more than 14-15 months out of a Harley AGM Sporty battery.
Old May 10, 2013 | 03:18 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Have battery checked first. Then at 2000rpm or so check the voltage at battery for around 14.8 DC volts. All OK? If not you may have done this like my right alternator rotor in the attachment. Need to put an AC (yes AC) meter on the three wire going to the regulator (unhook from regulator) (coming from primary) and make sure you are getting voltage on all three to a ground (about 36 volts on each one on my Softail..not sure about yours and it's possible you only have two wires.) That way you will know if it's the alternator.
Old May 10, 2013 | 03:32 PM
HOTLAP's Avatar
HOTLAP
OK I gotta ask...what the heck are you doing reving the hell out of your engine in neutral in the first place???
