I popped the clutch and hit my sister's car on my first dirtbike, when I was 11... Dad only showed me the front brake, and with the front tire off the ground the front brake doesn't do much to stop you. Add a little whiskey throttle to that and into the rear corner panel I went. So, you're not alone. Only difference is you are planning on hitting the open road, I wasn't at 11. Take your time. Relax. And practice. The riding course is good, but they can't teach you how to keep your bike under you, you have to do that yourself. They'll teach you strategies to use once moving, and some tricks for smoother starting and stopping, but once moving its up to you to keep it upright. Just keep practicing man. Don't be afraid of it, but also don't take it out in the open road until you feel very very comfortable. The more tense and afraid you are, the more clutch pop, whiskey throttle and locked up brakes you will get. You have to relax. Everything should be as smooth as butter when you're starting out. Rev up to 1500 RPM a few times and listen to the engine... Aim for that or just above that when slowly releasing the clutch. Let it begin to disengage and pull it back in... Feel for where that happens. Think of your hand position and how extended your fingers are right when the bike begins to catch first gear. You have to study your bike; the sounds, the feel of it, to know how it will respond to your input. Do some walk outs, barely disengaging the clutch until your bike begins to move slowly, then pull the clutch and just walk the bike forward with its momentum for 10-15 feet... And again, and again and again until you feel the balance. If you ever get into trouble just pull the clutch and front brake and pop your feet down to balance. That's your escape plan, so practice it. You bought the bike for a reason, because you want to ride, so go ride (10 feet at a time) until you get it. Have faith bud, we have all had those "oh ****, this is my first time on a bike, what the hell is going to happen next" thoughts. Enjoy the scoot...
Reason: Foul language removed by moderator
