Nightster wiring question: HELP! :-/
Old Jun 7, 2013 | 06:33 PM
D-Funk's Avatar
D-Funk
1st Gear
Default Nightster wiring question: HELP! :-/
So I bought a project...... Great start but some definite cobbling as been done. All the rear lights were cut off and now I'm installing blinkers and brake/tail light. I have figured out the signals, but how the heck do you wire the tail/brake light???!!!! I have a manual but there is no diagram for the nightster brake/tail light. Please help. Thank you.
Old Jun 7, 2013 | 06:55 PM
dirtycharlie's Avatar
dirtycharlie
4th Gear
The nightster uses the blinkers as a tail light. No actual tail light. I think it has a module that helps the signals act as tail
Old Jun 7, 2013 | 07:01 PM
D-Funk's Avatar
D-Funk
1st Gear
So there is no brake light? Yes there is a modulator. With my test light, it doesn't get brighter when I hit the brake.
Old Jun 8, 2013 | 12:48 AM
D-Funk's Avatar
D-Funk
1st Gear
I guess what I'm asking is if there is anybody that knows what colors to use (after or before the modulator for a tail and brake light)...... And also where should I cut in the load regulator for the LED blinkers? Before or after the modulator?
Old Jun 20, 2013 | 06:04 PM
D-Funk's Avatar
D-Funk
1st Gear
Bump...... Someone out there must have a good answer for me?
ultradriver
Dec 17, 2016 09:24 AM
kjay
May 25, 2011 09:17 PM
lou1
Oct 18, 2010 09:50 AM
perk21
Jan 19, 2010 09:34 PM
mikey0086
Nov 25, 2007 05:28 AM
