Help with LED stabilizer
=8^)
Custom dynamics part # 5.6 16. Load equalizer. I already installed the LEDs and they are blinking fast. So I ordered two of these for left and right. They are plug ins but the instructions make it look like a splice job. Not sure where to go with them
I don't know how to load pics. Got my bike on at one point. It's a black female plug in with a bulb tail. If I plug them into the turn signal ports there's no way of piggybacking the turn signals into it. I must be missing where to plug them in.
http://www.customdynamics.com/loadequalizer.htm Go to Item # GEN-5.6-15
or if you unplug the light and plug in the equalizer
can you plug the light into the end of the equalizer?
The only problem with resistors is that they create heat...this is why, IMHO, the "module" type of load equalizer is better [although more expensive] because the resistance is accomplished through cooler running electronics, pretty much alleviating any worries about where you place it.
'Matter of fact I just ordered this setup from Custom Dynamics, which includes the equalizer module, and it should be on my doorstep tomorrow:
As you can see, unlike the universal equalizers which are unpowered and require you to "cut into" the wiring circuit, the equalizer module only requires simple connection to your 12v+ and - @the battery to operate, and as far as attaching to the lighting circuit, you simply unplug your factory harness under the seat and plug the module inbetween the connectors and you're done...no cutting or splicing required.
When I was looking to change over to LED's for my Iron I looked at all the possible ways of doing it. Having worked on truck lighting for years and the associated headaches with customers wanting LED's, I had some experience. Funny story...well, I didn't think so at the time. Anyway, a truck comes in and one of the rear LED directionals was going ape$hit fast, so I started looking around for either resistors inline or a module. I found none, so I started looking along the inner frame rail and came upon this loop of wire, neatly covered in wire loom, all wrapped up with electrical tape, wire tied to the chassis. It looked like a good place to start to look so I began cutting through the mess and finally got down to the meat and potatoes of it and what did I find? A replacement taillight socket with a 1156 bulb in it wired into the circuit, acting as a "resistor." WTF!!! 'Only problem was, outside of it being hidden, was the fact that the bulb was blown, so there was no resisitance!!! Whoever installed the LED's was too fooking cheap [or stupid] to either add a resistor inline or pay for a module, so they went with this odd but affective [while the bulb remains intact anyway] method...k-ripes!!!
In the end and after my information quest was complete I really liked the idea of no splicing and cooler running operation that the module offered...maybe you should see if you can return the universals and maybe spend a little more on the module to save yourself some grief?
=8^)
=8^)
