SE Clutch kit and soft clutch option?
Old Jun 15, 2013 | 02:48 PM
chgofirefighter's Avatar
chgofirefighter
Default SE Clutch kit and soft clutch option?
I was going through all the stock previous parts used and given to me by the previous owner.. I came across a SE Clutch kit that apparently wasn't used or better said installed.
What is the benefit of this SE Clutch kit? Also, my clutch is extremely hard plus having a bad left shoulder doesn't help. I would like to reduce the fatigue of the clutch. Do need this done by a Harley tech or myself? What do I need to do?
Attached Thumbnails SE Clutch kit and soft clutch option?-stock-parts.jpg   SE Clutch kit and soft clutch option?-iron-exhaust-stand.jpg   SE Clutch kit and soft clutch option?-iron-oil-cooler.jpg   SE Clutch kit and soft clutch option?-iron-left-engine-view.jpg   SE Clutch kit and soft clutch option?-se-engine-and-intake.jpg
Old Jun 15, 2013 | 04:56 PM
rickss69's Avatar
rickss69
You can put a 883 diaphram spring in the clutch...won't find an easier pull.
Old Jun 16, 2013 | 09:00 AM
Mich's Avatar
Mich
Seeing that he has an Iron if it is still stock it should be very easy to pull now.
The clutch on my bike is quite easy to pull, almost too soft in my opinion, but it has hardly ever seen the rain or wet roads. Maybe your cable needs lubing or replacement already? The SE spring from what I understand will give you a stiffer feel at the lever.
Old Jun 17, 2013 | 08:49 PM
c0jones's Avatar
c0jones
Could that be the stock clutch parts with the SE box?
Old Jun 17, 2013 | 10:06 PM
chgofirefighter
Nope, box was sealed and never opened... I contacted the previous owner and he confirmed that the SE clutch kit was never used. The tech did something, don't recall what it was he said to the trans, some springs, etc were changed to compensate for the bikes new power
Old Jun 18, 2013 | 12:26 AM
rickss69's Avatar
rickss69
If it's hard to pull it's a safe bet the 883 spring was changed. If you don't have one I can send you mine for the price of shipping if you want.
Old Jun 18, 2013 | 06:55 AM
Mich's Avatar
Mich
Yes, it sounds like a stiffer spring is installed going back to the 883 spring will make it much easier and unless you are running well over 80hp should be more than adequate.
Old Jun 18, 2013 | 11:33 AM
IRON1250's Avatar
IRON1250
he is at 100 +hp according to his dyno. i'd leave the stiffer spring in there if it was me or you may find it slipping on you when your getting after it.
Old Jun 18, 2013 | 12:05 PM
rickss69's Avatar
rickss69
Recent clutch upgrade on mine, I found EnergyOne's 15% spring to be not that much greater pull over the 883. The 25% spring however is noticeable.
Old Jun 18, 2013 | 01:02 PM
IRON1250's Avatar
IRON1250
Agree with rick not to much harder pull but the extra grip is very noticeable.
