VS or not to VS....
Old Jul 8, 2013 | 06:04 PM
207Rider's Avatar
207Rider
Stage IV
Default VS or not to VS....
Been working on my first HD... custom build 883. Love the look of a velocity stack but is it worth the spend? I've heard I wont see any performance enhancement on an 883, Is this true?
Old Jul 10, 2013 | 05:23 AM
cavalier2000's Avatar
cavalier2000
I tried one on, on my 883 kept hitting my knee on it and it was pissing me off. as far as performance, unless you are building a land rocket who really cares (just my personal opinion) If you compare it to stock you may see a slight gain but I dare to say there is no intake out there that you will feel the difference
Old Jul 10, 2013 | 02:17 PM
$eventy2T's Avatar
$eventy2T
There are AM breathers that "look" like VS but have filter if that is an option.
Old Jul 10, 2013 | 04:13 PM
grancuda's Avatar
grancuda
I vote for a velocity stack, never had an issue with hitting it. Either do one or don't, avoid the "look" with a fake one that has an oversize bell & filter in the middle.
Old Jul 10, 2013 | 04:30 PM
cHarley's Avatar
cHarley
A real (unfiltered) velocity stack is fine if you're only running the bike at a drag strip and plan on frequently rebuilding the motor.
If you're running it on the street and expect the motor to last, you need a filter.
Velocity stacks with a filter typically only have a minimal square surface area of filter media, so the filter is typically either not going to provide good air filtration, or it will provide good filtration while sacrificing performance do to lack of air flow.
There's a reason for size of the ham cam, big sucker, heavy breather, etc. filters, and it relates to the square inches of surface area of the filter media vs air flow.
Your choice
Old Jul 10, 2013 | 05:21 PM
doctoraustin's Avatar
doctoraustin
had a buddy that had a velocity stack for about a month. It's fine if your just puttin around town. But if you want something you can do some long distance with you need a filter. I got the Arlen Ness Stage II big sucker and love it.
Old Jul 10, 2013 | 05:25 PM
grancuda's Avatar
grancuda
Depends on your riding environment most, not riding style. In a dry, dusty area, use an air cleaner. In a metro, lake, coastal environment, a VS could be fine for you.
Old Jul 10, 2013 | 06:18 PM
cHarley's Avatar
cHarley
Until you get stuck behind a dump truck spewing dirt, or a guy on the side of the road with a leaf blower, or a gust of wind that kicks up a bunch of dirt form an empty sandy lot, ......................
But then when I tore my 93,000 mile motor down for an upgrade last month, the cylinders still looked pristine.
Old Jul 10, 2013 | 07:55 PM
grancuda's Avatar
grancuda
A lot of people get a little too worked up over running a velocity stack.
Bike motors are pretty durable & generally don't get a ton of miles put on them. Also, we are taking about air cooled, push rod V-twins. These motors are easy to rebuild the top end IF you wear it out from too much debris. A $425 RSD air cleaner + tax cost more than a top end rebuild.
Old Jul 10, 2013 | 08:10 PM
rquest's Avatar
rquest
It will gunk up the carb. If you're the kind of guy that doesn't mind tinkering around, tearing things apart and cleaning them, okay. But if you're more of a set and forget type of person, uh, uh. I'm running a Hyper-charger on another bike that actually has a K&N inside, the best of both worlds!
