Re-assembly after 1200 work
Old Jul 12, 2013 | 07:03 AM
Iceman24's Avatar
Iceman24
Don't know what your auto parts stores are called in the UK, but we have chain stores w/everything imaginable. I'd use this, if you have something equal over there and scrape with "plastic" putty knife...don't want to mark the metal...
http://www.autozone.com/autozone/acc...ier=35009_0_0_
Old Jul 12, 2013 | 08:23 AM
roundy's Avatar
roundy
Need to find a product like that in the UK...
Old Jul 12, 2013 | 08:57 AM
rickss69's Avatar
rickss69
Originally Posted by roundy
ATF - as in automatic transmission fluid?
Reason I ask is that people say to use that to wipe in the bores after cleaning and I used some last night, the red stuff...
Yes, auto trans fluid...nothing better to use on pistons/rings for initial fire-up.
Old Jul 12, 2013 | 09:22 AM
roundy's Avatar
roundy
Sweet, so can I use that instead of assembly lube if I cant get any?
Old Jul 12, 2013 | 09:32 AM
rickss69's Avatar
rickss69
Yes - Assembly lube is more usefull on bearings, pushrod ends, rocker arms, lifters and cam lobes, but not entirely necessary in this case. Just use your normal engine oil and fill the pushrod tubes with oil to aid oil flow/pressure on initial start-up.
Chaos09
Mar 19, 2017 08:26 PM
Spankinstine
Jul 30, 2015 05:36 PM
MicOnti
Jun 10, 2010 07:30 PM
myzen
Jul 6, 2006 01:52 PM
sixfootape
Jul 16, 2005 03:18 AM
