Battery problem?
Old Jul 14, 2013 | 09:02 PM
Stick_Drifter's Avatar
Stick_Drifter
6th Gear
Default Battery problem?
I have a 1987 sportster that I have just started riding and it's actually the only bike ive ever rode just put about 50 miles on it and loved it so far.. Only problem in having is getting it to start sometimes.. I just bought the battery less than a year ago but when I start I've noticed the ticking sound that a drained battery makes when it doesn't have enought juice to start ! It typically will start after it sits over night but have noticed if I'm riding and turn the bike off to do something it just does that ticking sound... usually I could
Get it to start but today it wouldnt turn over at all had to push the bike off to start it.. I've read thru some stuff and I'm thinking it could be the voltage regulator and I have one that's new that came in a box off stuff that can with the bike from the previous owner but it says it's made for a bigger bike.. Will it work to use the one I have or am I way off could it be something else?
Old Jul 14, 2013 | 09:30 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
Get a voltmeter and get the voltages with the bike OFF, then with the lights on, then idle, then high idle. You should see if it's charging or not. You could have a loose connection, or a short, or a bad battery, or...
Old Jul 14, 2013 | 09:44 PM
Stick_Drifter
6th Gear
Thanks! I will check it out tomorrow . The bike was a mess when I got it I've been slowly working on it for about a year.. What type of readings should I be looking for?
Old Jul 14, 2013 | 10:32 PM
Stick_Drifter
6th Gear
and if it checks out bad will the other voltage regulator work for my bike?
glover_85
Electrical/Lighting/Alarm
Jul 18, 2014 01:26 PM
namelessghoul
Mar 25, 2014 03:54 PM
sammer4u
Jul 6, 2010 06:31 AM
popstheoldman
Sep 3, 2008 11:04 AM
RedBaron
Jul 21, 2006 04:42 PM
