Rear pulley teeth?
Old Aug 29, 2013 | 09:24 PM
JeffJA's Avatar
JeffJA
Default Rear pulley teeth?
I just bought a new rear pulley, but i just noticed its a 64 tooth and i believe my stock 09 1200 custom is a 68?
What will this affect if i run it? Or can i even use it?
Old Aug 29, 2013 | 09:38 PM
Scuba10jdl's Avatar
Scuba10jdl
You'll be running a lower overall gear ratio in every gear. This means you'll have less torque with higher horsepower. You will also be running lower RPM in every gear.
Old Aug 29, 2013 | 10:44 PM
JeffJA's Avatar
JeffJA
Will this affect the speedo?
Old Aug 30, 2013 | 12:04 AM
rickss69's Avatar
rickss69
Don't recall what model used a 64T pulley, but the offset will likely be different than your 68T. Your belt might be a tad long as well.
Old Aug 30, 2013 | 01:04 AM
rdunnill's Avatar
rdunnill
The '09 has a 1-inch pulley; earlier rubbermounts were 1.125-inch.
Old Aug 30, 2013 | 07:55 AM
Scuba10jdl's Avatar
Scuba10jdl
Yes, it will make you faster than you actually appear. Your speedo will read slow.
Old Aug 30, 2013 | 11:24 AM
dwagar's Avatar
dwagar
I don't understand this. Do you mean real numbers (ie it would affect a dyno run), or just seat of your pants?
Old Aug 30, 2013 | 11:49 AM
Scuba10jdl's Avatar
Scuba10jdl
It applies at the wheel, not the engine. Dynos measure this and then calculate the engine output. There is a good article on the NRHS tech tips section about HP and torque.
Old Aug 30, 2013 | 11:57 AM
dtaylor00's Avatar
dtaylor00
Here is a link to a site with some good info on changing your final gearing. Scroll halfway down. They also sell speedo correctors.
http://883sportster.webs.com/howtocr...rsportster.htm
Old Aug 30, 2013 | 12:07 PM
cHarley's Avatar
cHarley
Yes, it will make you appear to be going faster than you actually are.
I think you have it backwards.
Going from a 68T rear wheel pulley to a 64T pulley will give you a higher final gear ratio. The rear wheel will be turning a higher RPM in relation to the front (drive) pulley.
The speedo will be showing a speed that's less than your actual speed by ~6%.
