I've just realised that is a SuperLow wheel - did you forget the shocks?!
Nah...awaiting a belt and the struts were already on the bike. I can say that with a 61T/30T combo the 137T belt is way long...have a 135T on the way and hope I chose correctly.
these are the spec's, listed as "fitting" on 06 sporty, thought it would work on my 09, guess not.. "billet 65 tooth rear pulley for a Harley Sportster. 1- 1/8 wide.
Not sure what years this will fit, but I bought it for my 2006 Sporty.
The center hole measures 2 3/16 in. in diameter"
That central hole centres the pulley on the bearing housing. There are two different diameters depending on the wheel it is intended for. Older bikes with tapered roller bearings have a slightly smaller hole than later ball-race wheels, although the bolt pattern is the same.
Ok - We have gone from 64T to 65T...when you get your wheel off measure the offset between the pulleys. If it the 65T is about a 1/4" less then simply add a 1/4" spacer behind it and run a 1" belt. Your 137T belt may work back. An XR pulley would be a direct fit and is a 66T...I can give you a link when I get home from work.
Did you order the Buell XB12SS belt?
That's what I'm using, it's 135T.
Part Number G0500.1AKF
Id rather just re-sell it then mess around with it, thanks guys for all the info and help, the only reason i didnt research it more was because i picked it up cheap and it looked really cool!...lol
Again..thanks!
