2012 Sportster 48 Upgrades
Figuring out the theme/looks that you are after will save you from buying parts that you then stick on the shelve because it was not really what you were after...
For HD stuff New Castle HD or Horny Toad HD gives 20% discounts... Also, don't rule out your local dealer, if you ask, they might match those discounts (not all do, but do ask. I just did that with my local dealer and they matched pricing with what I needed.).
Above all, have fun in the process!!
1st round
2nd round
3rd round
4th round
https://www.hdforums.com/forum/sport...rty-eight.html
Some recommendations:
1. I would recommend going with a tuner from the get go. I have PowerVision and very happy with it. Call the guys at FuelMoto, great bunch of guys. Easy to use, can accommodate any changes you do to the bike...plus you can monitor directly all aspects of the bike in the screen (or put it away if you don't want to do that). Also works as a code reader and for resetting codes.
2. Ask, ask, ask! As many questions as you need to. Best to search for photos of the parts you want, read feedback on changes planned, etc. Do your research, do not buy stuff by impulse. Also check the classified section... you can get good deals on take offs from others (but when doing so, remember that you can get them new for 20% off, so be sure you are getting a deal when buying used, or slightly used).
3. Some Sportster models have parts that you can use on the 48. A good method of finding parts numbers is to use this site: http://www.shopronniesharleydavidson...partfinder.htm
4. You want a passenger setup. Our 48's don't come with passenger mounts nor pegs. You will need to find those mounts used or get the HD Passenger Footpeg Mount Kit-Part Number: 50203-04
5. Passenger will most likely want a backrest... you will need the - HD Docking Hardware Kit Part No. 53529-04 - Even if you do not get the backrest, it does not hurt to have it in place in case there is a need to attach a rack for carrying something... If nothing is mounted, and you want to hide the mounts, they sell covers for them. If that is the case you can order one set of each of these: (1) HD Short Rear Docking Hardware Cover Kit-Black Part No. 48221-10 and (1) HD Large Rear Docking Hardware Cover Kit-Black Part No. 48225-10
6. Grips. Harleys Get-a-Grip are very cool looking, comfortable, and the drop in without having to use any adhesive on them... highly recommended. - HD Get-a-Grip - Part No. 56100008
7. Lights! If you like your current bullet signals then highly recommend the Rear LED signal lights from Custom Dynamics and doing the front with the Dynamic Ringz (LED Driving Lights/Turn Signals) from them as well. You will also need their signal balancer. A quick call to them and they will get you the kit that also includes either clear or smoke lenses (so if you are planning to do smoke lenses... here is some small savings.
8. More on lights... - PIAA Extreme White Plus bulb to replace stock bulb in the headlight. Or save and get the LED headlight from HD (Daymaker LED Headlamp- Part Number 67700145).
9. Seats, a lot of folks here recommend Mustang seats as the have several setups with separate pads for rider and passenger. So if you want a solo look you can remove the passenger seat pad. And they are comfortable. But every as* is different, so test them at bikeweek events before buying...
That is all I have for now... everything else is either cosmetic, or the route I went is different from yours.
Check out some of the youtube vids in the link in my sig. Lots of bikes in there to get ideas from.
DKCustomProducts.com
and would be cool to have one similar with all the new updates and the sissy bar... your bike is one of those that I downloaded all the photos I could find
Anyway... back to normal programming... apologies to the OP for derailing this thread.
