Need turn signal help
Old Mar 9, 2007 | 01:29 PM
99XL883C's Avatar
99XL883C
Default RE: Need turn signal help
I think im also gonna try and open up the front turn signal housings to check out the wiring in there. Might be a little screwy. I'm positive that the rear turn signal housings of the new lights take a dual filament bulb whereas the original turn signals took only a single filament. The really odd thing is when I plug my original front turn signals back in (with the new back ones) things work fine.
Old Mar 12, 2007 | 02:03 PM
99XL883C's Avatar
99XL883C
found the problem, all fixed! thanks for the help
Old Mar 12, 2007 | 03:00 PM
Hagar the Horrible's Avatar
Hagar the Horrible
Well? What was the problem?
Old Jul 11, 2007 | 11:49 PM
cleanalby's Avatar
cleanalby
Stage I
I have the same problem, what was the fix ? The only difference is that I installed a different type of rear turn signal lamp. I'm pretty well convinced it's a ground issue. I am however intrequed by Hagar the Horrible's suggestion, "You may need to use blue black in the rear instead of purple black." . How can you come to this deduction (I'm willing to try just about anything) ? My manual says that the blue/black, should be used for DOM or HDI, not sure which. How does the blue/black wire play a role in the turn signals?
Would anyone know if the 4-ways use the same flasher as the turn signals? Oops, they use the turn signal module......right ??
I wish 99XL883C would post his cure for the problem !!
Old Dec 5, 2007 | 09:52 AM
pistole's Avatar
pistole
- hi.
- what was the solution to this problem ??
- I have the exact same problem with my '96 Heritage Softail,
ie , the hazard-flashing works fine.
- but , when I want to indicate direction , the direction-lights
stay LIT , but do not FLASH.
- driving me bonkers ... HELP !!!
Old Dec 5, 2007 | 12:01 PM
Stefan's Avatar
Stefan
Here is the 2002 Sportster wiring diagrams.
Old Dec 5, 2007 | 01:40 PM
Biker Trash's Avatar
Biker Trash
I had the non flashing problem as well. I installed a Load equalizer II from Badlands. ( got it from the Stealer) It was because my Currnet (mini bullets) lights didn't draw as much wattage as the stockers. That made the signal module "think" there was a burned out bulb. That was why my custom lights didn't work initially.
Old Dec 7, 2007 | 08:34 AM
pistole's Avatar
pistole
- thanks guys.
- will do some testing over the coming weekend, and
try to get them to FLASH.
- damn strange that the HAZARD FLASHING works , but
the direction lights are willing to be LIT but refuse to
FLASH.
cheers.
Old Dec 9, 2007 | 06:42 PM
dragracer's Avatar
dragracer
2nd Gear
ok here goes, i have the same problem, i have talked to several,tech's about this problem and the answers were all the same,it needs a load equalizer the dealer should have one it cost around 50 bucks,its the same as installing led lights.
Sportster Dane
Jul 18, 2019 07:19 AM
Patrick1979
Electrical/Lighting/Alarm
Jul 9, 2015 09:19 PM
voudoujoe
Apr 13, 2011 08:03 AM
jerryw618
Sep 6, 2009 01:24 PM
Hogaholic
Jan 4, 2007 11:09 PM
