Help needed installing fork shroud covers..
Old Oct 25, 2013 | 09:34 AM
cHarley's Avatar
cHarley
Originally Posted by chgofirefighter
For a guy that doesn't have any experience, it could be challenging. That's why I'm asking for help, not asking to get flamed or make me look bad..
There was no intent to flame or make you look bad. But I think you're making a mountain out of a rather simple, 1 bolt add-on. Now, if your problem is removing and reinstalling the wheel and fork tubes, that's covered in the SM and elsewhere.
Old Oct 25, 2013 | 09:35 AM
HarleyScuba's Avatar
HarleyScuba
Originally Posted by cHarley
Remove the sliders from the forks.
I don't think removing the sliders (fork lowers) will help. It appears the upper portion of the shroud surrounds the fork tube between the triple clamps. Therefore, you gotta slide the fork tubes up through the lower clamp, through the shroud and into the upper triple clamp. Easy peasy.
If your bike has 20,000 miles, it'd be a good time to grease the neck bearings while the tubes are removed from the triple trees.
https://www.hdforums.com/forum/sport...-bearings.html
Thanks, where did you get that scoop option on the bike, looks nice...
The pic was stolen off the interwebs. It's not my bike. That lower air scoop is available in the Harley Parts and Accessories Catalog:
http://www.harley-davidson.com/store...-front-spoiler
All the help you need is around here somewhere. Keep asking questions.
Old Oct 25, 2013 | 09:39 AM
cHarley's Avatar
cHarley
T
LOL, You're right, I hadn't downed my first cup of coffee yet.
Should have been - Remove fork tubes from trees.
Old Oct 25, 2013 | 11:50 AM
HarleyScuba
Cool beans. I had to do the mental hold-it-up-to-the-bike-and-scratch-your-head thing. My first thought was remove the lowers, too, and the fork seals/oil could be freshened up at the same time. I had half of it typed out for a reply before I went, "Wait a minute..."
Old Oct 25, 2013 | 01:15 PM
chgofirefighter's Avatar
chgofirefighter
No biggie~ got the directions directly from the vendor, which should of been included w the package but wasn't. I may get them done today or tomorrow...
Old Oct 26, 2013 | 06:31 PM
ScottyMack's Avatar
ScottyMack
I just did it. Get a friend and don't bother taking off the wheel or the brake calliper.
Get the front end up in the air on a motorcycle jack, loosen up the trees and then remove your master cylinder...I think that is what it is called, bring that down, have your buddy pull out the forks, slide on the shrouds, then he can run the forks back up...easy as that.
Bolt it all back together and done. Im just about to update some pics on my project post, but here is one. Took about 20 minutes.
Old Oct 26, 2013 | 06:40 PM
chgofirefighter
Wow, I wish I would of received this suggestion before I wen't ahead and did all that work, removed the break calibers, fender, wheel/tire and removed each tree individually but I got her done, but it was a PITA took me a few hours...
Nice bike~
Old Oct 26, 2013 | 06:51 PM
ScottyMack's Avatar
ScottyMack
Oh no! Really...****, when did you do it?
Old Oct 26, 2013 | 08:42 PM
chgofirefighter
Just got her done today~
Attached Thumbnails Help needed installing fork shroud covers..-front-completed.jpg   Help needed installing fork shroud covers..-completed-sideview.jpg   Help needed installing fork shroud covers..-fork-covers-installed.jpg   Help needed installing fork shroud covers..-project-started.jpg
Old Oct 26, 2013 | 09:38 PM
HarleyScuba
Looks great!
As far as the front wheel, fender and caliper goes, at least you got some practice. Having a buddy around to help is nice, I just gotta catch one before they start drinkin' so they pay attention and don't drop my ****. Usually, I get plenty of satisfaction working alone.
I gotta get me one of those jacks. Nice.
