Gross sound...
I have a set of Xieds on the way from DK, will that help at all?
The stock air cleaner does suck, thats why I changed it to a different one.
The old ham can has been a prominent characteristic of Sporty's for years. I like them, but I can see how a smaller ac shows more engine details.
John
I really like seeing more of the engine, however I will go back to a larger one if it really is that bad.
As for the sound, its sort of like…raspy now, compared to how the Short Shots made it sound. I had LOADS of compliments on how great it sounded before switching the AC.
Now most of my friends agree, pretty crappy sound. I wonder if the Xieds will help, I know they will help with the lean part of it.
Regarding pinging, you are too lean. The XiED's will fix that.
Short Shots have a tendency to to be a bit tinny and sharp sounding. When you had the stock air cleaner on it was restricting the flow of air, so you were not getting the full effect of the SS's. One way to deepen the tone of the SS's is to install some TTI W118's. Not only will it deepen the tone a bit, it will give a good bump in low and mid range power.
More general noise... (crappy?) the open element of the air cleaner produces a fair amount of noise...not sure if that is part of what you are hearing that you don't like.
On these new efi bikes, you cannot check plugs like you used to. There are more than a few threads on the proper way of checking plug color on EFI HD's, but the short of it is, you gotta be running for more than a few minutes at highway speed, then shut the engine off while at highway speed, coast to the side of the road and check the plugs then.
DKCustomProducts.com
Regarding the mods you've done I really think that you should get a tuner! The bike is probably running really lean right now. Don't want you to mess up a fine bike like yours!
