CNC 48 Points Cover
Old Dec 5, 2013 | 11:34 AM
awilson40's Avatar
awilson40
Default CNC 48 Points Cover
Heres my first attempt at CNC'd cover.
Once I verify fit I'll take another piece of Aluminum , paint it, then machine so the outer face will be black.
Old Dec 5, 2013 | 11:47 AM
jimlowe's Avatar
jimlowe
Nice!
Old Dec 5, 2013 | 11:58 AM
dustydog2's Avatar
dustydog2
Default changing timing cover xl1200c
looks like it is pop-riveted on...when I remove the old one, do I have to tap the holes for screws?.....Id like to know before I start...
Old Dec 5, 2013 | 03:58 PM
John Harper's Avatar
John Harper
I think you can get new rivets from HD. Or, tap it out.
John
Old Dec 5, 2013 | 04:46 PM
awilson40's Avatar
awilson40
Mine is screwed on
Old Dec 5, 2013 | 07:35 PM
Ployd4's Avatar
Ployd4
Looks great! Mine is also screwed in. I used to work as programmer and machinist with a 5 axis mill. Sure is nice to have access to the equipment. Where I work now we just have a manual mill and lathe. Make the most of the equipment as you can!
Old Dec 5, 2013 | 08:14 PM
awilson40's Avatar
awilson40
Thanks,
I have been out of CNC for a few years, Spent 20+ years in automotive. All 2 1/2 axis and mill/ turn stuff. Nothing complex. Spent the last 5 years 3D Thermoform mold designing in SolidWorks but no machining. We had other guys who did the toolpath. Now I'm at a University as a Lab tech, non teaching position but I get to play with a small Haas mill and Lathe to keep my skills up in case a student or professor needs something made. I ran across a great product that integrates with SolidWorks, HSMWorks. I cant say enough good about it.
Old Dec 11, 2013 | 07:04 AM
HarleyScuba's Avatar
HarleyScuba
Nice job. It's all about speed and feed.
The only thing I might consider is counter bore the screw holes for socket head bolts. I know that's not necessary, but it puts some sex on it.
Old Dec 11, 2013 | 10:40 AM
awilson40's Avatar
awilson40
Yep, I thought of that.
The stock cover is only .070 thick, I didnt want to go real think like some of the after market covers are. This one is made from .125 stock with the ring taken down to .070 . Not much thickness to counter bore the screw holes .
I have 2 more drying now with the outer face black and the ring and numbers raw alum.
Old Dec 12, 2013 | 04:08 PM
awilson40's Avatar
awilson40
Here is the finished product.
I also have a reverse version with the numbers black and outer face aluminum and just sprayed one entirely in black plastic dip just to see.
larsfum
EVO
Oct 27, 2015 09:06 PM
Vbound06
Mar 24, 2015 09:30 AM
Haddy
Nov 14, 2012 06:15 PM
hoethree
Sep 18, 2010 06:59 PM
vlad75
Apr 7, 2009 08:34 AM
