blow-by question..please respond peeps
Old Mar 16, 2007 | 08:22 AM
jakedog's Avatar
jakedog
Default RE: blow-by question..please respond peeps
You might want to review this:
http://www.mklsportster.com/xloilblowbyarticle.htm
Old Mar 16, 2007 | 09:40 AM
francos's Avatar
francos
thanks Jake .
That was really helpfull and gave me an Äądea of what Äąm dealÄąng wÄąth .
WÄąll do somethÄąng sÄąmÄąlar to my bÄąke when Äąll have some tÄąme .
Thnks agaÄąn.
Old Mar 16, 2007 | 10:46 AM
francos's Avatar
francos
just ordered a crakcase breather kit , a little filter and a fuel/oil line . Around 63 $$ all .
As Äą lÄąve overseas Äą presume shipping charges will be around the same prÄące as the order[:@]
But Äąm pretty sure Äąt wÄąll resolve my lÄąttle problem .
Probably Äą wÄąll receÄąve them next week .
WÄąll let you know guys how Äąt goes after the ÄąnstallatÄąon .
Old Mar 16, 2007 | 11:05 AM
bigtop1's Avatar
bigtop1
Just another solution for the blow-by problem. I took some vacuum hose and fitted it into the opening of the hollow bolts on the heads leading into the breather back plate. Angeled the hoses down and around the filter cover joining them with a hollow elbow.Connected both of them. Ran one hose out the back plate and down. I did have to grind down the protrusions on the filter that fit over the vacuum hoses at an angle where they werenewly placed into the ends of the hollow bolts.
Old Mar 16, 2007 | 01:11 PM
markdt's Avatar
markdt
I ran 2 rubber tubes down to a filter under the S&S carb. Clean it once a week, problem solved. If the oil is exccesive Check your oil return line If it is restricted the oil would pool a lot more in the heads..Mark...
Old Mar 16, 2007 | 04:00 PM
4ics's Avatar
4ics
Stage II
hello. I have already written a post, but I have not still resolved the problem; also I have tried in the forum some other post, but I have not found it. I have a sporty 883L/2005, with SEII exhaust and S&S air filter with K&N filter. although I have mounted a crankcase breather kit, continuous oil to having loss of fuel (green color) under the air filter. as I can resolve? thanks. hello. excused the interference (and the English not much correcting), I do not know if I have mistaken something, but creed that the question is correlated to the post.
[/align]
moto monkee
Jun 21, 2020 07:45 PM
Bonez76
Screamin Eagle CVO Models
Jan 20, 2019 01:26 PM
imbuhlman
Oil Archive (no new posts)
Apr 28, 2017 08:35 PM
Delawaredave
EVO
20
Jul 1, 2014 08:24 AM
Chop
Jan 28, 2012 12:20 PM
