Electrical Problem
Old Jan 17, 2014 | 10:03 AM
mrfikser's Avatar
mrfikser
Ohh, and how do you know the battery is good..have it load tested...just because the lights come on bright does not mean it is good...also check the main feed where the battery + goes to the fuses and connects to the battery....you problem too me does not sound like a bad ground (but I have been wrong before) ..it sound more like a corroded + wire or dirty contacts some where that is not allowing enough current to flow..
Old Jan 17, 2014 | 10:59 AM
Kelly Evans's Avatar
Kelly Evans
2nd Gear
Well I just did what you said and sprayed inside the ignition barrel and turned the key on and off several times, funny thing is, when I jiggle the key a bit in the 'on' position all the electrics go off so maybe it's a sure bet the ignition needs replacing?
Old Jan 17, 2014 | 11:07 AM
cHarley's Avatar
cHarley
I'd say, there's no maybe about it.
Old Jan 23, 2014 | 03:37 PM
Kelly Evans
2nd Gear
Well I ordered a new ignition and fitted it today and hey presto my bike is up and running again.
Hope this helps anyone else that may be suffering from this type of problem.
Thanks to all those that offered help and advice,.
Old Jan 24, 2014 | 02:44 PM
user 72098202's Avatar
user 72098202
If still no joy, disconnect and clean each "negative ground" connection. How old is the battery? Try a battery "Optimate" type of charger as that will tell you if the battery is holding a charge. If the battery is more than 3 year sold change it. Get a new AGM gel acid type I have one on my '99 XL which I keep out doors and retired so only use it once or twice a week and been on it 2 winters and no problems ever.
07SCBOB
Electrical/Lighting/Alarm
Mar 4, 2016 04:07 PM
jenn0227@msn.com
Oct 9, 2014 10:01 AM
keno
Sep 20, 2014 01:39 PM
knights
May 3, 2014 09:27 AM
blacklabel213
Sep 13, 2013 02:41 PM
