I like the ride height of my 72, but was thinking about getting better shocks. My thought process is to go with a longer shock for more suspension travel, to stop the bottoming out, but them getting lowering blocks to offset the added length. I realize that the lower blocks change the angle of the shocks, which will affect the suspension travel some. Am I out of my mind (I suspect I am)?
Funny you post this. I was just thinking about the same thing when I read another thread about lowering blocks. They said the ride was more comfy after the blocks were put on. Well, I need a better ride for my nightster but if it gets any lower I wont be able to use the lift I have. So I too was thinking about using longer shocks and a lowering block to give it a more comfy ride but still keep the height the same.
I've got 12" Street Glide Shocks on my 48, whilst they improved the ride massively, I felt that the bike was too high so fitted Tamarack 1" lowering blocks, the shocks were even better afterwards.
I think that the slightly less acute operating angle lets the shocks work better on the lighter bike.
Those shocks and the mount angle should raise your bike less than 1/2". This is exactly how mine is. After a week, it felt normal. Visually, you won't notice it.
Longer shocks equal longer travel. So, that should mean less chance of bottoming out.
I just put 13 inch progressive 412's on my sporty. However, I did not want lowering blocks, as I wanted to raise the back end and accommodate my long legs.
One thing to think about, I have read/heard from others that you need to be careful with some shocks and lowering blocks to make sure that you clear your pipes and belt guard, this is usually done with spacers.
Better to think it out before you ride and bang the cr@p out of something shiny.
An old thread, but why run longer shocks and then lowering the ride? Much better to get the 12" progressives that have the 3" of stroke made for your bike. With proper sag it sits at 11" when sitting on the bike here, or similar shocks. You don't have to mess with anything that can cause issues later.
