Apes
Old Mar 18, 2014 | 08:32 PM
Maine-Rider's Avatar
Maine-Rider
Yup knurled is the best route!
Old Mar 18, 2014 | 10:52 PM
TitanH-D's Avatar
TitanH-D
Stage III
Pinning them is super cheap if you are willing to do some work. I think it works best, safest. Its really not hard, allot cheaper than knurling if you go to a machine shop. Down side is there is really no adjustments...
Old Mar 19, 2014 | 02:41 AM
Spookymason's Avatar
Spookymason
Originally Posted by Sconnie
I have the Burly 14" bars w/ 14" wiring, mine have slipped a couple times. The last time I re-torqued the clamp I used Loctite on the bolts and they haven't moved since. Here's a pic of mine, you can see there is a bit of extra slack on the cables:
Thanks for the pic bike looks great but I'm thinking maybe 10"" z bars I will make my mind up one day.
Old Mar 19, 2014 | 02:51 AM
knights's Avatar
knights
if you check out my bike, iv got 10" z bars from road6customs.
i also didnt need to buy any cables just used the stock clutch and brake.
only thing i had to do was extend the electrical wires.
that was easy, a roll of wire from my local hardware store, some electrical tape and a knife.
and this was cos i wired them internally, which is super easy with the road6custom bars.
you might be able to get away with it if you keep them on the outside
Old Mar 19, 2014 | 03:04 AM
Spookymason
Thanks knights that's just what I wanted to hear I to would like to internally wire so that has made my mind up,cheaper to with stock cables did you have to re-route the cables to fit.
Old Mar 19, 2014 | 03:35 AM
knights's Avatar
knights
had to take off the clip that holds the brake cable under the triple tree.
i had to reroute my clutch cable but that was because i have the headlight visor fitted, so it was rubbing the paint at the side
Old Mar 19, 2014 | 05:53 AM
Spookymason
Cheers knights seen some 10" road 6 frisco bars with the caps for easy wire install so going to go that way. Thanks again.
Old Mar 19, 2014 | 10:52 AM
knights's Avatar
knights
yeah them caps make the internal wiring sooooo much easier.
got my bars from ebay, came from USA though so had to pay a little bit extra on import duty, but well worth it cos i couldnt find anything similar over here in the UK at the time
Old Mar 19, 2014 | 05:57 PM
Spookymason
Yeah I will have to do the same and pay the duty just hope it's not to much its Ł45 just for the shipping.
Old Mar 19, 2014 | 08:18 PM
Sconnie's Avatar
Sconnie
Haha, I hear ya man... I must have flip-flopped about 10 times on which bars to go with before I got mine. Good luck with the decision!
killathrilla
Sep 10, 2018 06:58 AM
TexFF
Nov 21, 2012 09:13 AM
Alain
May 3, 2010 11:06 PM
Razorback Rob
Jun 22, 2009 06:03 PM
BlessedHellride
Feb 24, 2007 10:40 AM
