Air Intake Disaster from Crankcase Breather - Questions!
Old Mar 18, 2014 | 10:39 AM
chugger93's Avatar
chugger93
Default Air Intake Disaster from Crankcase Breather - Questions!
Hey Everyone,
Bought my first Harley 2007 883L last July and just road it because I wanted to enjoy it. After being on these forums for some time and starting to slowly MOD my bike, my first issue is below. My bike has about 12K miles on it.
I have a screaming eagle intake and exhaust that came with the bike (private owner) and I've been reading about the breather bolts, tubes, etc. I decided to take off my air filter to see my hardware setup, etc.
I find this disgusting result from the oil going back into the air stream. I'm gonna convert over before I start riding again to a breather setup using DK's products.
My question is, how can I clean up the butterfly and intake channel? Could I start by spraying some seafoam straight in and go from there? I don't really know if I really wanna take off the intake and clean it up.
Old Mar 18, 2014 | 11:19 AM
dwagar's Avatar
dwagar
first thing I'd try would be hosing it out with carb cleaner.
Old Mar 18, 2014 | 11:45 AM
John Harper's Avatar
John Harper
They also have cleaner specifically for throttle bodies, as I recall.
John
Old Mar 18, 2014 | 11:47 AM
chugger93's Avatar
chugger93
But are those products only good to spray on when the engine isn't running so they arnt absorbed into the air stream? Or, vice versa
Old Mar 18, 2014 | 12:09 PM
Sailrider 1's Avatar
Sailrider 1
Doesn't matter. Carb cleaner will burn up in the combustion chamber. Won't hurt a thing.
Old Mar 18, 2014 | 12:45 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
I would clean it out with a towel that was soaked in carb cleaner.
Imagine what it looks like in the combustion chambers...
While almost all aftermarket air cleaners will flow more air than our engines can eat....they are NOT all created equal.
Picture of bike with typical stage 1 "air cleaner" feeding the hot oily air back into the air cleaner from the breathers.
Picture of a bike with external breathers and 5k miles
Another set of pictures-
This is an 06 Ultra that had the typical stage 1 "air cleaner" with the breathers going into the engine....at 8000 miles
This is the same 06 Ultra with external breathers with 27,000 miles more on it
Not only will an engine run better if it is getting just air and gas fed into it (vs. oxygen depleted air, gas and oil), but it will last longer also!
DK Custom Outlaw HiFlow Air Cleaners
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Mar 18, 2014 | 01:19 PM
Allen Riggs's Avatar
Allen Riggs
I just the exact thing. I have a Vance and Hines Duke intake and got sick of all of the oil going into my intake. I installed a new breather kit and blocked off the holes going into the cleaner from the old hoses. I really like the look of the kit. Easy job to do and the thing that surprised me most was how little in diameter the hole old breather were compared to this new kit. I'm surprised there was any ventilation happening at all with the old bolts. As far as the drain tube goes, I just got a few feet of 3/8 tube from O'Rieley auto and ran it down and out the bottom of the bike off centered to the right to avoid drips from getting on my tires. May be a placebo effect but I think in runs better at temp then before. That may be just my imagination; however, what is real is the clean air now going into my bike. Easy to do and worth the bucks/euro.
http://www.jpcycles.com/product/4000330
Old Mar 18, 2014 | 02:37 PM
awilson40's Avatar
awilson40
Kevin
You have almost sold me on removing the SE Intake and going with yours.
I really like the look of a RamFlo oval filter. Any Idea how I could fit this?
Perhaps buy your mounting kit with breathers and fit one of these :
http://www.debrix.com/Bendix-Keihin-...34-0040-vt.htm
Thanks
Attached Thumbnails Air Intake Disaster from Crankcase Breather - Questions!-ramflo400.jpg
Old Mar 18, 2014 | 02:46 PM
awilson40's Avatar
awilson40
I saw this on your site.
Its pretty cool too with the black mesh and the breather filter under.
Is it available ?
Attached Thumbnails Air Intake Disaster from Crankcase Breather - Questions!-round-style-ac.jpg
Old Mar 18, 2014 | 03:07 PM
chugger93's Avatar
chugger93
Great comparison photos DK! Am I too assume that by correcting my issue, I can get the carbon to burn off eventually...or at least some of it? lol...
