front brake switch repair
Old Mar 27, 2014 | 06:26 PM
Howler_LI's Avatar
Howler_LI
Default front brake switch repair
Brake light was on almost all the time. Pushing the front brake lever forward would often, but not always, turn the brake light off.
When I opened the switch housing the v-clip was missing, so I made one from scrap sheetmetal:
That did not fix the problem. Eventually I realized that the switch had to be moved in the opposite direction, away from the brake lever. So I took the shim out and made a new one from a piece of bailing wire. A simple "U" with one long leg and the both ends hammered flat, inserted on the opposite side of where you see the v-clip. That moved the switch and squared it in the housing. Brake light works correctly now, just the right amount of free play before the light comes on.
Old Mar 27, 2014 | 07:34 PM
Blackhawk48's Avatar
Blackhawk48
Nice, I actually just had my switch break while I was putting on my new bars. I just found some spare hardware laying in the garage that fit between the button and lever and mine works great now too.
Old Mar 27, 2014 | 07:43 PM
Allen Riggs's Avatar
Allen Riggs
I just did the same damn thing: broke the switch putting on some z-bars. Harley part $68 drag specialties part $18. Guess which one I went with?
Allen
Mike Simeone
EVO
Aug 26, 2018 08:52 AM
rideamap
Electrical/Lighting/Alarm
Sep 16, 2014 01:00 PM
cweiss
Aug 17, 2013 07:59 PM
tidefan60
Aug 7, 2010 09:48 AM
Rynb15
Apr 15, 2007 10:30 AM
