Wiring help
Old May 26, 2014 | 04:13 PM
Defiant808's Avatar
Defiant808
Stage III
Default Wiring help
Hello everyone. This is my first time here on the forums. I just recently picked up my first Harley. It's has on 86 evo on a rigid paugcho frame set up bobber style.
I just recently ripped all the wiring and re did a few Mickey Mouse things that the previous owner did to the bike.
I put the wiring back together and started to test out each circuit.
When I got to test my new dyna 2000i ignition module I saw that the indicator light would not go on when I turned the ignition on. This is when I found that there was no 12v going to the coil when the key was on. I checked everything else and all the wires looked like is connected correctly buy there was still no keyed 12v going to the coil.
I'm assuming that this is a faulty Ultima module. I hooked up a straight wire from my ignition keyed 12v directly to the coil and wallah the ignition module lit up.
Is it ok for me to bypass the module and run a straight wire from the ignition to the coil?
theterribleone_vdc
Shovelhead
Feb 26, 2017 02:40 PM
Defiant808
May 26, 2014 05:03 PM
ncottrell2009
Ironhead
Oct 18, 2012 02:06 PM
kick it
Shovelhead
Sep 25, 2008 02:01 PM
Freeroamin
Jun 27, 2006 03:58 PM
